Water Wetter
Old 03-12-2006, 08:42 AM
Dr Obnxs's Avatar
Dr Obnxs
Dr Obnxs is offline
There's a post how in another thread...
Originally Posted by Rich.Wolfson
How are you guys measuring temp differences?
There's a way to get it to display where your odometer is.
And you can use OBD-II diagnostics, or something like BiM-COM.
Matt
  #27
Old 03-12-2006, 08:46 AM
daemon2's Avatar
daemon2
daemon2 is offline
Yes
Originally Posted by MINIotaple
Anybody ever used it? Made by redline and it claims to decrease coolant temps by up to 30 degrees.
I've used it in my sportbike for track days. Definately helps keep her cool when she's being pushed.
  #28
Old 03-12-2006, 09:40 AM
Montana Miniac's Avatar
Montana Miniac
Montana Miniac is offline
I use Redline Water Wetter in all my vehicles. I would recommend it. A modified 97 Dodge Viper GTS is by far my greatest cooling challenge. This is one hot running engine. The use of Water Wetter in conjunction with other cooling mitigation like a duel core radiator, cooler thermostat, etc. all have helped. The Water Wetter helps lower the temps 3 to 10 degrees, but most of all, it helps to stabilize the temps. I use it with a 50/50 anti-freeze mix. No freezing problems. No corrosion. It is not a end all to your cooling concerns, but for a few bucks, it is money well spent i.m.o.
JD
USNAE2
16
06-17-2022 07:17 AM
PsychoRallye
21
02-17-2019 06:08 AM
ian260
03-29-2017 06:08 AM
vulkandino
10-31-2015 08:29 PM
martinb
10-07-2015 05:00 PM
Quick Reply: Water Wetter
