Water Wetter
Ive used it on several other cars, but not the Mini yet. My results weren't quite as dramatic as 30°, more like 5-10°. I believe for maximum temp reduction you have to use it with straight water, which I never do, I leave at least 25% antifreeze in. I'll probably be using it in my MC for the first time this summer.
-Keith
-Keith
I use it in all my performance vehicles...
To get the best benefit, use two bottles, 10% or so Antifreeze, and distilled water to fill. This will give lower temps, but will also effect the freeze point. I don't really have to worry about that where I live, though.
Now I've got one bottle in the Mini, but I"m thinking of changing out my coolant, and getting a bit more aggressive on heat capacity.
Matt
Matt
It made my highly modified Lotus Europa drivable in mid-summer (May - late November in Florida), so I'm a huge fan. I've also used in a Range Rover with a marginal cooling system - it's great. They now carry it in the larger auto parts stores so try a bottle in you current mix (drain some out first), and I bet that you notice overall improvment. Be careful about weak anti-freeze mix in the cold climate areas. Frozen systems don't work!
If you're real lazy...
Originally Posted by mbcoops
Can I just pour this into the tank, or does it need to be mixed properly with antifreeze and water first?
mb
mb
Matt
Our coolant is suposed to be permanant...
I guess it's not a question of laziness as much as ignorance to flushing the system and being more comfortable with just adding something to it.
So from your post I gather it is OK to do so.
mb
mb
Matt
If the active ingredients in Water Wetter are beneficial in a typical water/antifreeze mixture, I would think antifreeze manufacturers would be tempted to include them, and tout that on their packaging, maybe in a premium version of antifreeze. But, I can't remember ever seeing that. Anyone else?
My guess is water wetter effects the operating temperature range of the coolant. Probably has a higher freezing temp than coolant if manufacturers aren't using it. Since water wetter is designed for racing applications they don't have to worry about freezing temps!
And there really isn't a way to make your thermostat work more "efficiently". It opens and closes according to coolant temp lol. It's a good idea to use a lower thermostat like the M7 one if you have alot of mods.
The BEST thermostat would be one that opened regardless of operating temp depending on engine load like in BMWs. They're electrically heated if it senses WOT and other conditions even if coolant isn't up to temp.
The purpose of Water Wetter is not to change the temperature range of the coolant. It changes the thermal conductivity of water. Water has a very high thermal conductivity to begin with. The problem occurs when you mix water with antifreeze which has nearly zero thermal conductivity. A 50/50 mix takes the thermal conductivity down by half (but raises and boiling point and lowers the freezing point). What Water Wetter does is to double the thermal conductivity of the mix back up to what it was with pure water. It's a win-win situation. In racing engines where they only run pure water, it still works.
Kapps, has it right... just ask anyone that races shifter karts. A highly tuned IC or moto will run too cool with the right mix & require tape on the radiator. The flow is better with water wetter, there may even be a slight HP gain ( don't know because we use straight water with an engine dyno ). There are too many good reasons to use water wetter to list.
How can you tell the temp is down?
I am a fan of Water Wetter as reducing the surface tension of the water will only increase conductivity and allow the coolant to drain heat from the engine more efficiently. I use it in my Mini and our Spec 7 SCCA racer.
But since the thermostat controls the temp of the coolant and will open and close at a predetermined temperature, your temp gauge should show no change under normal circumstances and remain in the center of the range. If the engine started to go into an overheat cycle for some reason the WW would delay that but you really wouldn't "see" anything.
How are you guys measuring temp differences?
Rich
Rich
