"Oil change at a minimum of once a year...."
So I'm reading through the MINI TSB's and come across this rather disturbing bit of trivia. Appears to fly in the face of what's being bandied about concerning intervals.
"TSB #MO1 02 03 - However, all MINI's should have an engine oil change at a minimum of once a year, regardless of whether synthetic or petroleum-based oil is used."
I'm still a 3-5k mile change guy......Les
Yeah, that happened to us (even though we did our own oil change in between
). MINI had no problem with changing it after a year even though the indicator was nowhere near zero.
On the same subject, I just finished changing my own oil yesterday. The last MINI dealer oil change was done at 27k miles. The service indicator was reset. I did one myself at 36k and now I'm at 45k. Our service indicator says I still have 2k miles left before new oil is needed. If I were going with service indicator recommendations, I'd have 20k miles intervals
![Wink](https://www.northamericanmotoring.com/forums/images/smilies/wink.gif)
![EEK!](https://www.northamericanmotoring.com/forums/images/smilies/eek.gif)
Originally Posted by chows4us
Why is this disturbing? It says the exact same thing in the car's maintenaince manual that comes with the owners manual. For those that drive more than 10K miles they go by the little countdown meter. For those that drive under 10K miles a year you change it once a year. Sounds normal to me.
...Les
Ask a MINI Service Advisor
Lots of interesting stuff at
http://motoringfile.com/2006/03/02/a...ers/#more-4699
For example, the service interval is dynamic, based on how you drive
If you come in because a year passed but you are not within 300 mi of needing service:
Typically the service indicator will drop faster when the vehicle is driven under more harsh conditions such as stop and go traffic, very cold/hot conditions, or during more frequent short trips.
So when is the typical first service, you ask? There is no set amount but it does seem that more often than not, it is between 9000 and 11000 miles.
If you come in for an annual service and do not have the minimum recommended mileage then your MINI will receive an Annual LOW mileage oil service and the service indicator should not be reset. You should return to your MINI dealer either 1 year from that date of this service or when the SII reads 300 miles to go (whichever comes first) in order to receive a FULL Oil service.
My May '02 build MCS owners manual does not talk about oil changes other than at the 12k mile intervals.
If you are still under the MINI maintenance program, the dealer will do just an oil and filter change if you are about to hit the 12 month interval and are still showing miles remaining on the service interval counter. Then when you hit the >300 miles to zero, you can take the car in for its first service interval and get another oil and filter change (in addition to the rest of the initial service interval maintenance items). (This is an amplification on the second part of jdmarino's post above - there is more than an oil service that is performed as the first service where the service interval counter is reset.)
Kimolaoha
07-05-2023 01:04 PM
