Fuel Additive for Fuel Injectors
on
Carbon does build up no matter which gas you use but if you use 93 octanne as recommended you will "hopefully" have less trouble later down the road. The cleaner the fuel burns the better!
If you are to the problem stage there is a product called "seafoam" for cleaning injectors. I have not needed it for the 4 month old MCS but it is a superior product if you need an injector cleaner!
Carbon build-up is an entirely different problem. For the injectors, if you are using a top tier fuel, you shouldn't have problems, If you suspect the injectors are fouling, Lucas makes the best cleaner, IMHO. Their octane booster is also one of the best, raising the octane # 3 full numbers, as well as a full dose of injector cleaner.
on
Originally Posted by Barnabas
seafoam actually hurt performance on my friends' honda! I actually know a few people who lost power after using seafoam...haha. They had so much carbon buildup that it was giving them extra power due to the increased compression ratio!
Hopefully you won't get that far
I used it to treat a problem, not prevent or try to diagnose...If your not having injector issues and/or have low mileage I would not use it.
Hmmm. Sounds like it is time to re-visit www.toptiergas.com. Gas that conforms to the TopTier detergent spec, while it may not be free of intake deposits, will have the absolute lowest level of intake deposits. In a former lifetime, I had a 1986 VW GTI that had intake deposits after only 10,000 miles. After a de-carbonization procedure, I have been running Chevron gas in all the cars I own. After a cummulative mileage that is in excess of 700,000 miles, I have never had a problem with intake deposits. If none of the TopTier suppliers do business in your area, then a detergent additive like Chevron Techron may be in order; but if a TopTier supplier is in your area, you would be better served to just switch suppliers.
on
I haven't noticed anything strange. I was just wondering if I should try something to prevent some sort of build up.
At my last scheduled maintenance the dealer wanted to do a pressure cleaning of my injectors. When he got to the part were they would have to take off my supercharger to do it I said no. After that though, they got me to wondering.
on
I use a bottle of Chevron Techron at every oil change on all my cars. The MINI hasn't had an oil change yet, but it's almost there. A good friend of mine is the service manager for a Porsche dealer & he tells me Techron is the only thing that they've used that actually works. Probably not needed especially on our new cars, but heck it won't hurt it either.
If you can measure
Originally Posted by cooper99
So what results do you get from it? Peace of mind only?
Matt
Originally Posted by caminifan
Are you using the bottle of Techron because Chevron gas is not available in your neck of the woods? If Chevron gas is available, the additional bottle is just a "peace of mind" factor; it isn't going to really make a difference - the Techron in the gas (if you fill with Chevron Supreme every time) is what makes the difference.
patsum
26
05-29-2021 06:29 PM
Manny_cooper
09-03-2015 05:48 AM
