36MM Socket Wrench - Where?
For the time being, I've been using a set of Channel Lock pliers as a substitute for the 36mm socket. It works well, but you have to take care not to strip the nut on the filter canister.
![](http://www.hardwarestore.com/media/product/604452_front200.jpg)
I've looked around at Home Depot and local auto parts stores for a 36mm socket, to no avail. Some stores have offered to special order one for me for about $25, but the sockets are almost always deep impact and thus too long for our oil changing applications. Sears has one that looks promising... But it's a 12-point socket and not available for local pick-up.
Right now, I've narrowed my choices between the Mini Mania 36mm socket (which is 3/8" drive) and eBay.
HTH!
HTH!
Originally Posted by MINIotaple
Okay, so I'm about to do an oil change and I was wondering where I can find the 36MM wrench or socket since it seems like a rather odd size. Can I get it from Sears or Home Depot? Can I use something else?
How's the GRE comin' along?
![Wink](https://www.northamericanmotoring.com/forums/images/smilies/wink.gif)
I used the Craftsman 36mm a couple of times but it has been far better to use the right socket. Use a flex-head ratchet and the job is even easier. My torque wrench is 3/8ths so with the adapter there was not much room; I recommend proper torque on everything. The 3/8ths low-profile socket can be had at any Mercedes parts department #606-589-01-09-00, the Hazet #2169-36 is also available from Samstag Sales http://www.samstagsales.com/, or from Terry Sayther http://www.terrysaytherauto.com/MINI...htm#MINISocket while your in Austin, by far the easiest route.
Originally Posted by bumble's angel
I went to home depot to find the socket a couple months back and asked if they had one. The sales assoiate looked at me and said they dont make sockets that big.![EEK!](https://www.northamericanmotoring.com/forums/images/smilies/eek.gif)
I was like WTF.
![Eek](https://www.northamericanmotoring.com/forums/images/smilies/eek2.gif)
i wouldn't suggest this tool to miniotaple...
miniotaple, go to sears. they have the 36mm's readily available.
HTH!
HTH!
First of all my suggestion is still to buy the correct tool but since others are suggesting alternatives I thought I would throw a wrench into the works. I have a 36 mm Service Wrench from Martin Tools #1236mm purchased from Amazon.com it was very inexpensive and it was shipped overnight; they’re going for $18.00 right now. It has a short handle so it can fit in the tight space around the filter cover. I bought it to use on the camshaft because the ARP camshaft bolt would not install using the BMW cam sprocket lock. I used the stock bolt anyway, but the point is it works on the filter cover.
Once again save yourself some aggravation and capitalize on the legwork of someone else, start out right, go to the Mercedes dealer or Terry Sayther and if you don’t have one get a flex-head ratchet.
![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
The auto parts stores around here have cheap 36mm axle nut sockets made of stamped metal. Much thinner so more clearance than a regular socket.
I bought a Klann 3/8" drive, shallow 36mm socket from Samstag Sales. Hazet makes one, too. Click on the BMW link and look under Oil Service.
EVMini
09-28-2015 10:20 AM
09-10-2015 11:55 AM
