Clock stuck on time
I had this happen once. The clock stopped, and so did the odometer!
I had to shut the car off, and when I turned it back on, both the clock and odo had updated to the correct numbers, but still wouldn't update. It fixed itself after the car was shut off overnight, hasn't happened since. Best advice I can give is let it sit, and see what happens. Then you might try disconnecting the battery for about 10 minutes, and seeing if it's fixed.
07-16-2020 12:54 PM
PSIChocolate
08-13-2015 12:46 PM
dchang0
08-10-2015 03:37 PM
