What needs to be greased?
Sadly most trucks these days still use decades old automotive technology. Wheel bearings, tie rod ends, and ball joints are sealed now and last a very long time without any maintenance. Thanks to synthetic oils and tighter engines, 3K-5K oil changes are also becoming a thing of the past for more and more cars!
If you have a sunroof, the tracks could probably use a greasing once every few years. Probably wouldn't hurt to do the door hinges and latches too since they are exposed to the elements.
Under drivers cowl-- wiper linkage with light oil
door hinges,hood latches& the door doesn't open too far things --30-40wt oil
hood release cable -- light oil
seat runners --multi purpose grease
doorlocks -- oil containing graphite
door weatherstrips, boot seal & any other rubber --silicone spray --(spray on rag & wipe on)
sunroof rails with--??
And my favorite--squeaky windows--will need to remove door panels to grease (see squeaky window fix for directions)
That should keep you buisy for awhile!
