Squeaky Mouse in the Trunk...
Old 05-11-2006 | 07:11 PM
jjasonbbo's Avatar
jjasonbbo
Once in a while My car will just randomly squeak in the rear.. I think its the fuel pump cause thats the only thing mechanical back there that I know of anyway... the problem is I can't make it do it for the dealer so they won't fix it.. and sometime after this squeaking it will idle real ruff like lack of fuel I can rev the motor a little and it smoothes out.. How can I get this fixed with only 25k on the car?? And is it even the fuel pump??
Old 05-15-2006 | 03:12 PM
DownSize's Avatar
DownSize
I guess you just have to find time to take it to the dealer, cause im sure it will cost a forune to fix, whatever the problem is. atleast call them and let them know you are having a problem, then atleast it will be in the system that you had problems with the part in case of any serious failure.
Old 05-15-2006 | 05:04 PM
namwob's Avatar
namwob
Is it an ocassional squeak, squeak or a longer squeal like a motor that needs oil?
Seatbacks can develop a squeak (folding them down may help rule them out. The hatch can squeak, Swaybar/endlinks,or exhaust hangers. Intermittent low choppy idle (remedied by blipping the gas) is a normal Mini bug, probably unrelated.
Let us know what you find out.
Old 05-15-2006 | 06:36 PM
jjasonbbo's Avatar
jjasonbbo
See thats just it.. it not coming from the engine compartment.. it is coming from the back of the car even at idle... I have got on the ground while it was doing it and it sounds like if a wheel bearing were bad but obviosly its not that cause the car is not moving... I have told the dealer about the last time it was serviced and they didn't do anything cause they can't make it squeak... Its still under warranty so I am gonna make them do something about it next time I take it in... It has to be the fuel pump I think cause its the only thing in the back of the car the is doing anything while the car is at idle and not moving... Don't you think???
Old 05-15-2006 | 08:10 PM
namwob's Avatar
namwob
I meant squeal/squeak like dry bearings of an electric motor not engine related. Anyway, the fuel pump is under the rear seat directly behind the driver (US). It sounds like it is more likely related to the fuel vapor leak detection pump which is hidded under the right rear wheel cavity's plastic liner... Don't you think?
On another note, If I can smell my clutch, I know I'm driving wrong.
Old 05-16-2006 | 06:52 AM
Ozbone's Avatar
Ozbone
I started hearing just such a noise from the rear of my '05 MCS. At first I thought it was the seatbelt (retractor) housings. Little by little I eliminated sources. Guess what ... its the rear hatch. It is not fully latched no matter how I try it won't fully latch; its like 75% closed but I can pop it open without much effort. Try yours. I'm going to have it adjusted at the dealer when I finish my driving light install.
Old 05-16-2006 | 02:14 PM
jjasonbbo's Avatar
jjasonbbo
hmmm.. That maybe it!! what wheel is it behind? driver or passenger?
Old 05-16-2006 | 06:21 PM
namwob's Avatar
namwob
Again,passenger right rear.above the tire under the plastic wheel tub liner. Access from outside the car.ok?
Make sure & flag the dealership an hour labor for enlightening them. Settle for a T-shirt.
Old 03-25-2012 | 02:26 PM
lidle91's Avatar
lidle91
Did you ever figure out what the squeak was behind the passenger seat?
sorsha6
06-13-2019 07:00 AM
dhayashi
05-17-2012 08:30 AM
Boneman
12-18-2006 09:13 PM
grimmrimmer
Tires, Wheels, & Brakes
10-28-2006 11:07 AM
Quick Reply: Squeaky Mouse in the Trunk...
