Bleeding Clutch Slave Cylinder
I'm trying to bleed the clutch slave cylinder and not having much luck! I have been using the standard brake bleeding technique of pumping the pedal, will this work with the clutch? What is the trick to this that I'm missing? I've made sure that the brake fluid is completely topped off as I know the clutch gets its fluid from the brake resevoir.
Thanks,
Mike
Thanks,
Mike
A vacuum pump has worked best for me. You are also supposed to completely compress the slave cylinder with a special tool (you can make this), but I have done it both ways. Using the manual brake bleed method is the last resort as it is hit or miss, but if you must, try disconnecting the slave cylinder and pointing the bleeder up like a syringe to get the air out.
Like a moth drawn to a flame, I just got through bleeding the clutch slave cyl. If you're not mechanically inclined, I suggest, in a word, DON'T! For me, traditional method of using a Mighty-Vac didn't work and I got air into the system. After taking out the 2 ea. 10mm bolts, had to fab a tool similar to the factory's which compresses the piston, then using a pressure bleeder, finally got all the air out after 3 sessions. At least I'm an expert(has-been under pressure) now.
ShadyCoop
09-20-2015 08:57 AM
09-16-2015 06:22 AM
09-16-2015 06:18 AM
wildwestrider
09-04-2015 06:25 AM
