question on narrowband oxygen sensor
PM me about this. I installed my plx r-300 this way last month, with narrowband simulation. The short of it is, it works. BUT, I had to chase a few gremlins.
ONE, as DR. O has said in his plx thread, the knock sensor has a separate ground and is not the right type for the plx to understand [it produces super-low voltages]. Simply put, when I tapped it [I forgot that he had warned against this!], the plx ADDED like 10x the knock voltage statically and my car freaked. It pulled all kinds of timing and operated super-rich. I cut the knock analog input that I had soldered in and re-insulated the wire, and things are great now, sans any input now for knock to the plx.
The narrowband output works well, because the car runs great. But, I'm working on ways to reduce the noise inherent in the new circuit, to make the narrowband signal as intact as possible.
BUT, there's still an issue for me with the oxygen sensor heater. The stock narrowband needs to reveal that it is 'heated up' for the car's ecu to think it's working, even if the ecu is getting a proper narrowband signal. Otherwise, it throws a CEL to say that the sensor is not functioning.
The plx manual says to trick the ecu with a 20 ohm 10 watt resistor. WELL, I got the appropriate resistors and my friend and I worked out a really elegant solution by splicing it into the former female connector [we cut the narrowband harness and inserted this into the connector]. BUT, the cel still goes off.
This is the only error I've got. I'm really busy with finals and haven't figured this out yet. I see two possibilities. One, the resistor does not provide the proper resistance [see my next post for an update]. Two, the resistors may not yet be completing a circuit as they should.
I'm still working on this issue. But, good news is that the narrowband simulation works as it should. The ecu is adapting as normal, I've lost no power, and I'm happy. Now, if only I can trick the ecu...
Just a minute ago, I got curious and decided to go read the resistance across the o2 sensor heater circuit. It reads between 3.6 and 4.2 ohms. That's way below what the PLX manual said would be needed [20 ohms]. I guess that's why my CEL is coming on. I'm gonna get some new resistors and hopefully that will fix things.
I've got a question, though. Given that the wires read about 4 ohms across them [but this does oscillate a little, like I wrote above!], what would be the proper resistance to go to? I'm thinking 4 or maybe 5 ohms. Any thoughts? Thanks!
What you want to do...
Just a thought...
But it's probably easier to get a 3, 3.5 and 4 ohm resistor set, and just use the one that works. Maybe ever 4.5. Resistance goes up with temp (for most things, at least).
Matt
Originally Posted by Dr Obnxs
Is look at the current and voltage when hot. That way, your resistor will mimic the load of the heater when it's at operating temp....
Just a thought...
Matt
Just a thought...
Matt
About the o2 sensor heater circuit code... When I first installed the current resistors, there was no light. I drove a couple of hours, came home [turned the car off], and then set off on a 5 hour journey the next day... An hour into the journey, I stopped for coffee, and when I turned the car back on [third cycle since install] the CEL came on.
I guessed that either the circuit is kinda lazy [and it only checks/complains intermittently, ie every couple of ignition cycles] or it has some fail-safe built in and will only trip the CEL after seeing the same error a few times. Maybe both.
Well, I checked with a good friend and MINI guru in Miami, Luis Sanchez of Precision Autowerks, and now I have an idea or two about what may be happening. The o2 sensor heater circuit is there as a way for the ecu to make sure that the o2 sensor is working [so that it may ensure that the signal which it is sending the ecu is reliable...]. BUT, it seems that the heater circuit is only active for a narrow window during which the car is initially idling [and it apparently becomes inactive around the time when you begin your journey]. It is supposed to check with each ignition cycle. Since it took three cycles to get a light, I guess the car plays dumb for a while before deciding the sensor is 'bad.'
Therefore, beating this CEL may be harder than I think. After clearing my codes, I'll have to cycle the car a few times with whatever combo I try to ensure that it's working right.
Sorry for being long-winded. I hope that this helps someone .
with your scanner, look for a pending code after you've driven once after clearing all the codes. Some throw the CEL right away, some take 3 repeats.
The heater is to shorten the amount of time before closed loop control can be done with the sensor.....
Matt
Matt
alistaircookie
10-08-2015 10:52 AM
thebordella
08-31-2015 01:37 PM
