Idle vibrations
I have been through plenty of problems with my mini...you get them fixed and move on. Reason we have warranty. I am at 49k and taking my car in one last time under warranty for an issue that just arose (bad t-map sensor)
You're gonna give up the best handling car because of a few CEL's...
Thats like getting in a relationship with soemone and you have a few fights and just end it...
ps...motor mounts have been known to blow and leak too...check under the hood
The reason I brought up the lemon law was not because of the idle vibrations. It is because of the SES light that has come on for the fourth time for the same reason. Just a little frustrating to have to drive 180 miles roundtrip to the dealership, then wait for 4 hours at the dealership, every other month to fix the same problem over and over again; especially in a car that is less than a year old.
Regardless, my problems are not about the original topic of rain gear's "idle vibration". I guess I am planning on heading to San Antonio on Tuesday so I will be sure to post the fix for this issue when I return .
Originally Posted by RAin geAR
haven't noticed anything while driving. sorry if i'm a little slow here, but i'm still not sure how to inspect the motor mounts.
The lower mount will require ramps or jacking the car up & jack stands.
Start the car, with a small pry bar or big screw driver, see if you can isolate the buzz. There may be nothing wrong with the motor mounts. If true you should be able to sniff the problem out searching for a loose component. If it is a mount, with the pry bar, wedge the lower mount & see if the noise goes away.
idle vibrations -
I'm experiencing quite a lot of what was discussed in this thread, my engine light kept coming on and off and on and off and the dealer reprogrammed it even though the fault code pointed to an oxygen sensor, but I read somewhere that others having this issue had a leak from an intake duct at the supercharger and they replaced it and it resolved the problem, rough idle was gone and now it was smoother
I'm trying to convince the dealer I have the same problem but they won't do anything about it...the car feels under powered for a cooper S...
I get heavy vibrations when I accelerate.... my seat buzzes and I can feel the vibrations in my chest, back... all over... not comfortable when you are trying to concentrate on the road...
motor mounts
I already had the hydraulic engine mount replaced over 2 years ago cause of engine rattle when shutting off the engine.
I'm wondering if this all happened because of negligence and now my car has some sort of internal damage that can not be traced until my warranty runs out.... i'm not sure anymore....
vibrations are normal but within reason... it's like a vibrating massage chair but without the massage... just irritation...
still getting vibrations at 2100 RPM
I got my car back from the dealer, they said they could not find any problems with any codes, transmission, engine, motor mounts, tranny mounts etc. but I still have the same problem....
Engine makes loud vibrations that seem to be vibrating the exhaust at exactly 2100 RPM, and it buzzes my seat.
It happens in Neutral, Park, or if I'm driving at 2K RPM, I can feel the vibrations buzzing my seat, maybe at that RPM the engine is vibrating the exhaust causing it to touch the undercarriage of the car?
It's really really annoying. I also checked my fuel economy on the highway on a short 30 min @ 100K /hr drive my fuel consumption was 6.8 liters per hundred kilometers. I don’t think I have any sensor problems/vacuum leaks again the dealer looked for problems like these and could not confirm any.
I even looked underneath the car and found that the bottom of the driver’s side what appears to be the bottom of the transmission and was stained a bit with dark looking grease/oil. I'm hoping it was from the valve cover gasket leak this leaked all the way down the passenger side of the engine and covered the drive shaft. The dealer would have mentioned this since the car has been in so many times for these problems. I also recently had an oil change so if the transmission was leaking I hope they would have said something.
[FONT='Calibri','sans-serif']Cheers[/FONT]
