Knocking noise
Does the knocking disappear upon disengaging the clutch (in other words, pressing the clutch pedal down)? If so, there is a service bulletin written against the issue and they claim the problem comes from the insufficient dampening capabilities of the stock flywheel on (I believe) '02/'03 MINIs. Course, when my MINI exhibited the same problem (and I have an '03 Cooper S as well), the dealership notified me that it was most likely the throwout bearing causing the noise and since I was out of warranty, the cost to replace those related components and labor would be placed upon me. So I've just happily dealt with the minor annoyance and will replace those parts when necessary.
i have an 05" mcs, dealing with the exact same problem. My car has been in twice to the dealer and they have replaced the flywheel and clutch twice... still makes that noise unless the clutch is engaged. The dealer said they are working on creating a part to fix the problem, and they wont know for a couple of months. So in the meanwhile since my car is still under warranty, i'm gonna get the statement in writing and wait to get more info.
Just a thought.
Originally Posted by 002
If it is present with someone holding down the clutch peddle and it is a knock, not a higher pitch tap and is at idle and focused above the intercooler, I would say supercharger blades knocking.
And the award for longest run on sentence goes to...
unxpectederror
10-22-2015 12:16 PM
Miniwaukee
09-29-2015 09:22 AM
