Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
Has anyone in Tampa used any particular garage for oil changes after your Mini is no longer covered by the warranty? I'm considering a garage called Charlie's British Cars. I left a message for them asking if they service Mini Coopers. I don't want to drive to Palm Harbor from North Tampa and pay a ridiculous amount just to get the oil changed.
You are probably looking at a little bit of research. Start with independent service shops that do BMW service. The filter fousing and the socket that is needed to remove it is a standard BMW service item. Also, the procedure for replacing the filter is very similar between BMW and MINI (locations are different, but the torque settings are the same).
You might try asking over at www.sunshineminis.org; I got mine done at MiniWerks in Largo (just a 5.000 mile one before the 10,000 scheduled oil change).
