The Great Power Steering Pump Failure/Problems Thread
#252
#254
I replaced mine about 10K miles ago, but thanks for the heads up.
Got the updated version of OEM FAn so no guard is required it is built in....and it was on my door step in 2 days....takes only 5 mins to install.
Here: http://www.bavauto.com/shop.asp
#255
This is scary indeed!
#257
I'm not sure what to do. I just want to warn all early year Mini owners. I had no warning, noise, signs of this. I just parked one morning and when I got in to dirve home no power steering. Upon further investigation:
Electrical terminal completley burned off!!
Wires into pump fried!!!
I have no idea how my car did not burst into flames!!
Please make sure your power steering pump fans are working. Apparently
mine had locked up and I assume it shorted out the pump. Car is an 11-2002
build S with 58k miles. No warranty and never had any pump work done. It is original to the car.
I'm not sure I have any recourse with MINI-USA but I feel I need make them aware of my experience.
So, did the fan die and the pump started burning (but continued to provide power steering for a while) before you parked? (Then was kaput the next morning?)
#260
Mine went out two weeks ago (same scenario, although I didn't see it to verify that it was charcoal). 02 Cooper CVT. This is my third go-round with the power steering components, including pump replacement, column issues, and now the fan (and wiring harness and thermo). Apparently the fan locked, the fuse blew, the car overheated (quickly), and fused the thermo housing. I'm still trying to fix the resulting problems, and am up to about $1100 at this point (on this month's problem).
I'm really disturbed to see that this seems to be a not-uncommon problem. Personally, I can't believe the wiring harness upgrade wasn't a recall issue, because from what I understand it has either been the cause of my problem, or at least the reason it went from bad to much worse.
I'd appreciate any tips in dealing with my dealer. I tried to go to a private MINI repair person, but his work didn't fix the coolant leak and now he won't return my calls. Indy's definitely no place to own an out-of-warranty MINI.
#262
I need to get in touch with a service rep.
I also feel this should be a recall.
Check this out:
http://www.mini2.com/forum/faults-fixes/49527-important-have-you-had-power-steering-pump-failure-please-vote-yes-no-47.htmlA
According to this poll more than half have had failures!!!
#266
Cost
Sorry - I didn't see the question frenchie- The cost for the replacement unit was $350 plus $15 freight from BBA. I feel it is worth it to have the unlimited replacement available..I think this may be a common issue. Add another $23 for the fluid from BMW and we are on the road for $388. Week two with no problems from the amateur mechanics work (me). Cost quoted from the local MINI dealer was $1350.
I would do it again...BBA was very helpful even though the cost was higher than expected...a board problem rather than a run on problem. I don't know the cost difference for the two repairs.
Take care all.
Take care all.
#268
#269
#270
See... you hit the spot. The exhaust tips -apparently- burn people, the failed pumps so far did not burn anyone (luckily). It's crazy how the recall items are determined, dont you think?
#271
This probably belongs in Post #1 of the Spontaneous Engine Bay Fires sticky (and I see the OP has posted in that thread recently).
Problem is, I see that SCoop hasn't updated the list since April of last year, and has not even posted anywhere on NAM for a year. What a shame -- this first post was a nice running tally but now it's missing valuable, supplemental data.
#272
#273
power steering pump
2006 MCS with 25,000 miles on it. It's not super loud yet, but it is audible...I'm hearing a high pitched whine coming from the engine bay while the car is idling (can't hear it when inside the cockpit, but when standing outside). Reminds me of a whine I heard from a similar MINI (way louder, but same pitch) while at the dealer once when the MA said that's the sound of the power steering pump going bad. Is this accurate or do most R53 MINIs have such a whine (when it's not the supercharger)?
Thanks,
Greg
Thanks,
Greg
#274
Thanks,
Greg
Thanks,
Greg
#275
My steering died a few weeks ago, and we decided to order the Haynes Mini book and check the fan, fuse, etc. ourselves and attempt the Power Steering Pump cleaning if needed. After waiting a week and half for the book, it finally arrived. $30.
We then discovered we needed the following:
a torque wrench ($16 from Pep Boys), extra Pentosin fluid ($22 from BMW), three self locking nuts ($2.34 ea also from BMW), and a socket set with a various sizes to get the nuts and bolts off. We also used a screwdriver to remove the hose clamp (called a circlip in the book.)
So we managed to get the fan off, fluid out, but are having trouble removing the hose pipe from the reservoir on top from the pump itself. We got the clip off, two bolts in the back, the single bolt from the supply pipe and now we are stuck.
Can someone tell us how to get the pump out?
And is it easier to get the pump out if we remove the pipe and electrical plugs first?
Thanks so much, we are totally stuck :S
