The Great Power Steering Pump Failure/Problems Thread
#451
#453
power steering fail 2005
thanks to anybody who may be able to help us out.
question: dose anybody have experience of damage done due to power steering pump failure by continued use after failure / steering column / bushings / suspension / bearings / or any other front wheel drive wear? thanks for your input. owner of 05 s cab 24,000 miles.
power 2 u
power 2 u
#454
Video coming soon.
I just got a call that my power steering pump is fixed. They will ship it today. Since I was the one that uninstall that thing, well I'm going to install it. This time I will have a friend help me take video so it can help some of you guys on the installation process. It was'nt hard to get it off, as loong as you have the right tools. Expect the video next week-end.
#455
Steering Pump Disaster
I have an 03 Mini Cooper, with about 137,000 miles on it. I had my mechanic (who is a close friend of the family), look into the steering, and he said the pump, and the fan are shot...however, when i first start the car and cut the wheel immediately, the power steering works anywhere from 5 seconds, to just under a minute, and than all of the sudden its gone.
I am new to this board, but love my mini, and don't want to have to give it up...unfortunately at 137K, the repairs are getting to be more of a burden than anything else. Is there a reliable source for after market steering pumps/fans???
Any help would be greatly appreciated.
Best regards,
C-bol
Best regards,
C-bol
#457
Mine was doing it every now and then for some odd reason and i'm at 100k. But I just waited it out because I didn't feel like buying a new one yet and it's been working BETTER than ever for the last month or so! It's so smooth, seems like the lines were clogged or something. Just wait it out! lol
#458
#460
Good reading...gets kinda deep pretty quick!
http://en.wikipedia.org/wiki/DC_motor
http://en.wikipedia.org/wiki/Brushed_DC_electric_motor
#461
In an electric DC motor with brushes...like the PS motor....heat is the main enemy..as it gets hotter, the brushes tend to wear faster, and once the brushes get too far from the commutator, at some point, the transfer of electricity will stop....and the motor will too. Of course if could be the wireing, or the electronics.....but since the carbon from the brushes have nowhere to go (unlike an alternator that is vented), it seems to buildup in the motor, and short it out. Sounds like it is time for a new/rebilt unit.
#462
Have you guys seen the sticky thread at the beginning regarding engine bay fires originating from failed PS pumps (and/or the PS pump fan)? When the PS pump cut out for the first time on my 2003 MCS at 95Kmiles, I had it replaced the next day (the shop that I went to was putting a PS pump into another 03 MCS when I drove there) . I parked the car away from other cars and in open areas during that 14 hour period just in case
#463
But the Moral of the story is...if something is not working right...get it looked at!! I am very happy to hear you got your car looked at ASAP!!
Sometimes the wiring harness for the PS pump chaifs....If I had to bet money...that is what caused most of the fires. Warning signs seem to include, but are not limited to PS pumps that stay on after a car is shut off....if this happens beware IMO. I would look closely at the wiring and the pump.
#464
No, there were no noises coming out of the engine compartment to indicate any kind of problem. It came with a 90 day warrenty for the drive train and I was not going to spend $2300 on the warrenty. I'm sure if I have to replace the power steering unit it will cost me $1500 or so after pricing them on the internet. I just thought there may be an easy way to bleed the pump or insure that there is no air causing the problem.
Go here: https://www.northamericanmotoring.co...tructions.html
step by step removal/installation....$1500 for a new pump? Not sure where you got that quote but my new (re-manufactured) pump from BBA was 450 (pump + $150 core charge + $35 shipping - round trip for the core )
#465
#466
#467
Kinda worried about making a mess with fluid leaking out. Turning the wheels and all.
#468
The pump is the low point....it should be empty pretty quick...be sure to get the correct petrosin ps fluid...BMW, mini, vw, napa, and some auto parts stores sell it...as do most vendors... It is kinda $$, but I would use all fresh fluid when re-installing the pump...I would also install a new ps fan too to safeguard the new pump...I got one a while back from WayMotWorks for I think $133 a while back...fan only..you install it on the old bracket.
#470
Yeah...and if you read the thread...a few of the cars that caught fire had had the problem with the PS pump for months.....Usually it is the Fan the fails...it gets missed....then the PS pump fails.....usually that is it.
#471
The regular radiator cooling fan can stay on after the car is driven a bit, especialy on a hot day, or driven hard.
Most people that had the ps pump get stck on, were having to disconnect the battery to prevent the battery from dieing because the ps pump was stuck on. Even when driving...the ps pump only runs when called to do so...the advantage of the electric ps pump, it runs only when needed. This helps to improve mpg...at the cost of complexity. Most new cars are rapidly switching to electric ps pumps for this reason.
#473
On an 05's, you can add the PS duct from MOSS MINI....this will help to ensure a supply of cool air, and protect the PS fan...and keep it from failing, possibly leading to a PS Pump failure......
Most people have said swapping out the pump is not too hard......
$200 or so for a rebuilt (you usually must **** YOUR unit for rebuilding, and wait for it to be done, then returned or.....500$+ for new......plus install and fluid if you pay someone to do it....and the new cooling fan...IF you reuse the current bracket that holds it can be as low as $133......or as high as 180+!!
Good Luck!
#474
power steering and idle problem
iv recently got my first mini a 2003 mcs.over the past couple weeks my steering has gotten pretty stiff. i know the whine they have is normal and doesnt seem to be very loud, the p/s fluid is full and in good condition. it also has memory steer at lower speeds. is this a sign of pump failure or possible seized ball joints? my other issue is sometimes i get a rough idle/fluctuation. it seems to run great and only does this at idle after driving for at least ten minutes but doesnt always do it any ideas on what it could be?
thanks
thanks
#475
Power steering a little temperamental
Well I know what's coming, everything that is common Mini issues happens to my car. So sometimes when I crank my car up I don't have power steering for a few seconds, the longest being about 15 seconds. I realize this means I'm not too far from needing a p/s pump but that's fine because I have a extended warranty. My question is how long does this normally go on before complete failure, because I'm probably moving to Tennessee and would like to take it to Nashville Mini dealer for the work. I realize that there is no way to know when it will fail but just from experience how long have yours (mini community) have lastest after first noticing problems. Also will changing out the fluid help any, previous cars I've worked on p/s issues have been at least temporarily fixed by a fluid exchange.
