Rattle : Supercharger / water pump
#101
Supercharger lube
Eddie, you are 'da man', what you did is exactly what I have been planning on doing soon. I refuse to let the front or rear oil chamber go dry and eat my wallet when a little PM and some mods will let you check it and maintain it easily.
I would like to PM you about your experience.
YD
YD
Yo'sDad, My thoughts exactly, Eddie it would be great if you had the pictures for us DIY people. Only a suggestion I have is that while it was at optimal fill on the bench to make up a dip stick so it could be checked occasionally after that.
#102
This was not a dealer but a repair shop.... We found that a new supercharger from the dealer would be about $2K. But we found this used one (rebuilt) for about $1400. So by the the time I bought the SC and water pump and coolant and thermostat and labor it was about $2200.
Then 5 days later it overheated again. Now it might be just a blown head gasket or a cracked head. The head will be removed and then x-rayed... I am told that the labor for a head gasket is 9 hours... so head gasket at about $100 and labor (@$90 /hr) will run me another $1200.
My wife is not too happy and wants to sell the car.. Do I still trust it after all of this? Hopefully the head will not be cracked since it will be much more at that point.
If I were you, before I would let that shop touch my car again I would have then reconcile those differences or find someone I trust for a second opinion.
Sorry for your problems, hope you get it sorted out.
#105
No one here can answer that for you..
as it depends on the discretion of the dealer you take it to, or Mini USA.
Also, you have to be sure what's causing the trouble. While most SC failures do make lots of noise, not all do. And there are many other failures that can make noise as well.
To localize your noise, the easiest way is to use some vacuum hose or the like, and use it as a stethescope to find EXACTLY where the noise is coming from. This will tell you where you need to do the work.
Matt
Matt
#106
One word of caution here...
the leaking of the lube IS the failure, and it leads to more failures of the catastrophic veriety. While it is possible that topping up will stave off worse failures, it's also likely that the seals will get worse, as they are designed to last the life of the SC.
I'm not trying to say that tapping and adding access to the oil chambers is a waste of time, but if the fluid is going, just adding more may not get you much more than more time to get it fixed right, and may not even do that if the leakage accelerates.
Just something to think about.
Matt
ps, it may be that getting access to top the sections off really does increase life. But it may also be the case that getting a used SC, having Steigemeier re-work it, and just leave it on the shelf will serve your interests better. I honestly don't know.
Matt
#107
I too have been a person lucky enough to run into this situation. My 2002 MCS had been making noise for a bit, but I had put off checking the oil level, as I did not identify this as the problem. Last Friday, the charger started to make significantly more noise, so I stopped driving it.
I bought a used charger off of here, and also managed to aquire a spare from a friend with a race team. Since the one I bought had a 5% larger pulley, and I really was trying to avoid losing performance, I put the stock one on.
After pulling my charger off, I pulled the fill plugs, to find no oil in the water pump drive end. I pulled the cover, and found that the needle bearing had totally disintegrated, but my gears were fairly well preserved.So, I now have a properly running car and charger again. Of course I checked and added a little oil to both ends of the charger before the new (to me) one went on.
I have to admit, I am a little surprised that the noise coming from the engine bay is not enough for most people to stop very quickly, but maybe my carjust made a LOT of noise, since the bearing took itself out, not the gear.
Regardless, I now have a perfectly good, used supercharger for sale, assuming I can find a bearing for my water pump drive. If anyone needs one, I still have all of the packing to ship.
#111
Can an oil fill location be installed by drilling and tapping the hole for a small threaded plug? The opening could then be used to check oil level and fill as needed.
Click the attachment to see where I am thinking.
This is purely being thrown out there as an idea, I have no idea how thick the material is in the locations I am suggesting.
#112
I think someone is doing that already...
Matt
#115
Is MINI aware of the failing superchargers in 02/03/04 model years (oil loss = loss of gear lubrication = gear points getting sheared off = loss of spin of water pump = overheating condition = warped head...etc!!!!)
And if they are aware, does anyone know if a design change was implemented in the 05 or 06 model years SuperChargers to try to rectify this problem?
For that matter, were there ANY design modifications on the part of the manufacturer in subsequent model years, or is the 2002 supercharger pretty much exactly the same unit as the ones found on a 2006?
Thanks and rock on,
-boognish
Thanks and rock on,
-boognish
#116
I'm not sureprised...
I don't think it's a design issue, it seems to be a manufacturing issue, as there are lots of SCs that get the expected life without failure. That said, there's no reason for them to admit to anything, no matter the number of events that occure. There are other references to BMW (not just Mini) being very, very slow to admit to design or warranty issues. I'm not aware that there was ever a recall on the CVT trannies, yet the technology was pulled in favor of a standard auto.
Also, I don't know the stats on this one. If one estimated about 500 failures, while higher than one would like to see, there have been about 300k MCSs or so made. That's a bit over 0.1% While it would be much better to see this number down less than 1 in 10k, it's still a low amount.
Matt
Matt
#117
Matt
Matt
thats all
#118
We've created a service in our shop here in Mass. to service the superchargers around 80,000 mi. and hopefully head off this problem for some folks.
http://massmotoringclub.com/index.php?topic=244.0
some of you other independents may want to do this for your clients as well. It's beneficial in more ways than one. Many of the rubber seals get replaced, and they tend to develop "undetectable" leaks when they get older causing check engine lights with lean codes, also your water pump and thermostat are replaced, which at 80k isn't really a bad idea. At the same time, hoses and other components that tend to make contact with each other can be checked heading off some serious issues later.
Pete. D.T. Automotive.
#120
#121
If the water pump drive is damaged, this company wont rebuild it. on a good unit though, a rebuild will be somewhere around 700 -800, takes about a week. A new unit from Mini is around 1400.00 I think.
#122
Hey guys -
What are your thoughts on this;
I have no rattle during idle or light acceleration, no odd noises at all.
But if I say; cruise in 2nd, push in the clutch, let off the throttle, shift into 3rd, let out the clutch, and floor it, I hear a sound from the passenger side like loose change sliding around -- I'm wondering if it is the gears starting to grind when the supercharger is engaged.
If I drive normally the sound doesn't present itself. Boost also builds near-instantly as it always has, and peaks the same..
Think my oil is drying up?
(2003 with ~10,300 miles & -15% reduction pulley -- it's sat in a garage most of it's life.)
Edit; I should probably also mention that this is about 3,000 miles after the pulley, the 3-piece self-aligning pulley from MiniMania..
#123
I'd bet it's something else...
maybe loose change? The fact that it's from the passenger side means you should look elsewhere for your problems... See if you can isolate it more than just "passenger side"....
Check oil level.
Check coolant level.
How do you know your boost? Have a guage?
Do you have access to any OBD-II data logging stuff?
Matt
Check oil level.
Matt
#124
Check oil level.
Matt
Check oil level.
Matt
Anyway, I spoke to a few of our Benz technicians here at work and went for a ride with one, they looked over a couple things, they think it's probably just the belt tensioner, which does make sense considering when the sound presents itself. That or the clutching mechanism..
Yes, I have an Autometer boost gauge -- oil & coolant levels are good. New coolant, 3,000 miles on the oil.
#125
Benzes have SC clutches
Minis don't. The sound failure that is the subject of this thread is the water pump gears in the back of the SC, at the center/front of the engine. Tensioners go bad, that's for sure, and there is increased belt tension when under boost as opposed to when the by-pass valve is open. But the pully on the SC is fixed to the shaft, and while the front shaft of the SC has gone south in a few cars, most of the failures is at the rear where the waterpump drive gears are, and that leads to overheating.
A good way to help isolate this is with a lenght of rubber hose to use as a steathescope. Have someone rev the motor while the hood is open and see if you can replicate the sound. Quick jabs to the gas pedal should get the bypass valve to close, increasing the load to the tensioner.
Matt
Matt
