MCSa harsh downshift
5 times out of 10, when I decelerate to a stop in my 2006 MCSa, there is a very abrupt and harsh downshift right before actually coming to a stop. I would suspect it is the 2nd gear to 1st gear downshift. Sometimes this happens as I step on the brake to slow down at the beginning of a sharp corner, too. Sometimes, the MCSa is as smooth as silk through all downshifts to a nice smooth stop. Others, I get whiplash. Why is it that the MCSa has so many quirks? Don't mind if it does this often, I can live with it. The question is, is there any harm being done to the transmission when this occurs?
Thanks. Rock on,
-boognish
Thanks. Rock on,
-boognish
I also have an 06 MCSa. It does not do what you describe when in drive.
I think there is a feature such that, when you use the paddels in the drive mode (as opposed to having shifted over to sport), the software 'learns' your preferences. Thus, if you tend to drive in a sporty way, it assumes you want this. Early on I noticed that, after some spirited driving (with me shifting), the automatic shiftpoints were more aggresive. I did get some harsh downshifts as you describe. Now, I almost always use the sport mode when shifting aggresively, and that seems to have solved the problem. When in drive it is almost always smooth.
If this doesn't solve it, I'd say you have a problem (probably a simple software fix). I have driven two MCSa's and neither did what you describe with the frequency you describe.
I am not much help here as I drive in Manual mode 100% of the time, but...I am pretty sure that when you are not in manual mode, the car always starts in second, and thus never goes into first unless you put it into first yourself. Someone please correct me if I am wrong .
Thanks. Rock on,
-boognish
Thanks. Rock on,
-boognish
on
My 04/2005 (17k miles)MCSa has the harse downshift from time to time. But I think it happens due to driving style. What I mean is if you are the person who usually waits to brake till your very close to the car in front of you @ a light then it will downshift hard. Start to brake sooner and this problem seems to occur less frequently.
Let me know if this helps. It seems to of in my car.
on
Yup, mine never downshifts into first when slowing to a stop. It downshifts only as far as second, and then starts up again in second. Only way to get it into first is to use a paddle, or really gas it.
Originally Posted by fishbulb
my wife's late 05 MCSa also downshifts pretty hard when coming to a stop. IT's not every time, but it does happen. I don't drive her's enough around town to figure out any specific pattern to it.....
My MCSa does the harsh downshift thing also, so I slide the shifter into SD as I near a stop and it doesn't downshift so hard.
As for stopping in 2nd gear when using the manual mode...that is normal. You must downshift again manually in order to start again in first gear. When I first took my MINI for a test drive, the salesman was with me and told me that the manual auto shifter was just a 5-speed. Imagine his surprise [not to mention utter shock] when I showed him the 6-speed "idea". He had never seen that before and just assumed it was a 5-speed auto, like the Bimmers.
shahriar35
09-14-2015 11:53 PM
