2003 MC-ECU and Engine revisions
Originally Posted by Peter Buccetti
...{snip} It only has 14K miles on it and seems to run perfectly but reports P0171 (too lean).
Some folks have reported that changing to aftermarket ECU A/F maps (MTH, Unichip) have addressed the problem. You can read more in the following thread:
SES light with P0171 code
...{snip}Does anyone know how I can check which version the engine is and which version the ECU is?
...{snip}Evidently there was more than one version of the 03 engine and the computer revision has to match the engine revision.
But, the Tritec engine comes (came) in a normally aspirated version for the Cooper and a supercharged version for the S. If your ECU (and software) were for a normally aspirated Tritec and you have a supercharged Tritec installed, I don't think you would be able to even start it!
Theo
problem solved
Just wanted to follow-up that the dealer finally did fix this problem. Even though they had told me they had replaced ALL the Oxygen sensors before (several hundred dollars ago), they replaced another one and the problem is gone. It has been a couple of months with no SES light. Everything else about this car has been great - but I don't think I would ever buy another MINI.
alistaircookie
10-08-2015 11:52 AM
