wiring harness in battery box problems
on
I have been having problems with the wiring harness in the battery box. Basically what is happening is the car will die or won't start. It will turn over adn oall of the interior accessories come on but the engine will nto start. If I move the cables and wires around then everything is fine, for a while until it happens again. It is with the accessory cable that runs out of the fuse box and down the drivers side of the car. I have pulled it out and checked it for damage and there are no signs of anything wrong. No outward signs that is.
Any advise would be greatly appreicated. I am out of warranty so taking it is not an option.
on
Yeah, I thought of that, but it is not ont he wire with the charge. There are two wires, one with a charge goes to the starter adn the other has a 200 Amp fuse. I think it is shorted out. There are four smaller wires that come off of it too. Two of them come form the air bag control to the charge for the starter wire. Not sure what the other two are for. It is mysterious though since all of the accessories work, the car just own't run, oh and the boot own't open adn one of the brake lights come on.:impatient
Try checking the ground straps. A bad ground in these cars can cause some strange problems. Also check the end of your positive battery cable for corrosion. If the insulation on the battery cable looks lumpy, you may have corrosion in the cable. Hope this helps. I hate electrical problems!!
on
Wohnson89
06-10-2020 04:53 AM
ryGuyMCS
10-20-2015 02:24 PM
PSIChocolate
08-13-2015 12:46 PM
DWooderson
08-10-2015 09:12 AM
