Bleeding the Clutch
Bleeding the Clutch
This weekend I used my handy Power Bleeder and changed the brake fluid, what a easy job it is with the right tools. But what about the clutch. According the shop manual I need a special tool to depress the clutch slave cylinder before I can bleed the line. Can I do this without this special tool.
I also changed the SC belt myself for the first time (brought the belt tension tool from Outmotoring last week) It was a great weekend.
You do not need the special tool to bleed the clutch. You just need something the correct length to depress the clutch pedal. Anything that can be wedged between the clutch pedal and the seat will work. You can adjust the seat travel to get the length just right to compress the clutch. Some people have used a length of wood. I used a 2 foot "Quick Grip" Bar Clamp because it was easy to adjust to a proper length.
on
To properly bleed the slave.....Compress it with a c-clamp so the rod is all the way in and then gravity bleed it if you dont have a power bleeder for the resivior. you dont want the valve all the way out cuz air could be caught in that area which you wont get out....Compressing it will bring everthing back in and the trapped air if any, will bleed out.
i wouldnt do the pedal trick.
Brake/clutch fluid is hydroscopic. It absorbs mositure and will rust the internals of the slave cylinder and other parts if not changed every few years..
on
I was able to take off the slave cylinder and compress the piston by hand, then wedge it between the flange on the tranny where it mounts and the actuation lever. I had a friend in the car depress the pedal gently while I opened the bleeder valve (with hose attached) and held the slave cylinder in place where I had it wedged. This requires a helper. Made a big difference since there was air in it from last place that bled it.
With regard to a post above about using DOT 5 silicone brake fluid, it's excellent for collector cars in storage but I don't recommend it to anyone who would be tracking their car. However, there is a DOT 5.1 racing silicone fluid which is extremely expensive but why go to the trouble? Just use good 'ol DOT 4.
share the same resevoir, so you'd have to strip down all the brake calipers to do
a proper change.
Plus, silicone fluid is more compressible than regular fluid and doesn't perform as well except
for it's much lower affinity for water, and that very quality can actually backfire on you,
since any water that does get in stays out of solution, where it can rust things.
drrigg
05-27-2022 03:31 AM
eliseo1981
11-02-2015 11:24 AM
unxpectederror
10-22-2015 12:16 PM
10-01-2015 12:13 PM
09-28-2015 09:13 AM
