Can anyone tell me...?
on
Where is the fresh air intake for the a/c? I've got an unpleasant odor developing in the system. There's a product from BG Chemicals calles Frigi-fresh that you can spray into the fresh air intake that will kill anything lurking in the system and leave a fresh scent. I just can't find the fresh air intake.
I'd guess that the cabin filter is the culprit. It is located under the glove compartment. Unlatch the plastic tabs, and pull the filter out (noting it's orientation). The new filter slides right in. You can find them online for around $30. My cabin smelled like wet dog with the AC on until I changed this filter!
Or, you could smoke a nice spicy Honduran to cover up the smell!
on
Well, I'm not so sure the filter is the problem. It just got changed with service #2 about 6 weeks ago. The problem was there before that is has been there since. I just didn't remember to say anything about it when the car was in. Typical. Anyway, I've got the Frigi-fresh stuff and it works great. I've used it for years. Most cars use the fresh air intake below the windshield but not the MINI. The search goes on............................
Oh, and I may enjoy a Cuban instead of a Honduran tonight!
on
He is correct. The passenger side vent is where the fresh air comes into the ventilation system of the MINI. It's easier to open the bonnet which exposes the entire chamber under the vent.
Changing the filter is fairly easy. Note that part of it slides up vertically along a track with the remain part curved to horizontal. Like said above, just note how it comes out and install the new one back in the same way. I'm a smoker (yes, IN THE MINI) and I change this filter more often than the Inspections. Does wonders to get a fresh one.
Related to this is something I did that I wouldn't recommend. I have the '02 with the vent filter that decomposes and falls apart. I replaced these with an air conditioner filter pad. They look okay, but they hold a lot of moisture after a good rain. Instant foggy windows inside until the defrost heats up and defrosts the glass. I'm still looking for a less dense material. If anyone knows of a black material I'd be most appreciative.
PS, the smelliest of stenches is in the nostrils of the beholder.
Last edited by ToBFree; 09-20-2006 at 06:19 PM. Reason: Read all posts more closely.
on
pkillur
09-26-2015 01:57 PM
