weather strip/seal wear - normal?
it appears my drivers side window has shaved off/worn away a bit of the weather seal/strp that seals the door and window after closing. it's an area about 1/4" wide by 1" tall. the area is located about a quarter of the way up the b pillar from the top of the door. has anyone else noticed this? it's not worn at all on the passenger side - i usually roll down both windowns at the same time. does the window need to be adjusted? would this be covered under warranty? is it even worht getting fixed - would it just wear again - plus, i doubt it's hurting anything.
brother i
Tires, Wheels, & Brakes
08-23-2015 01:15 PM
PelicanParts.com
08-04-2015 02:45 PM
