Help finding part or repair
During a recent brake pad change, I decided to use "good'n'tight" in/lbs tightening the guide bolts (the ones inside the rubber sleeve) instead of taking 10 minutes and looking up the correct torque value. Well, you guessed it, I stripped a hex fitting .
I retrieved the part name and # from the ETK database, but have had no luck finding ANY brake hardware online. Am I stuck getting brow-beaten at the dealership ordering the part, or should I just pull it with some vice grips and weld a bit onto it for future use?
Gil-galad
Eastern Iowa MINIs
63
11-17-2016 02:54 PM
bc219
08-10-2015 11:22 AM
marendt428
08-08-2015 04:44 AM
