Booom!
Old 11-05-2006, 06:44 PM
Smokey's Avatar
Smokey
Smokey is offline
Originally Posted by CooperSAZ
and 18 hours to install. (18 hours are for transferring stuff over to the new head and installation)
Is the tech blind and a ex-high school shop teacher?
Disclaimer: no offense meant to ex-high school shop teacher, it's just all of them I know don't have all their fingers and of course no offense meant to blind people, but they should be working on cars for dealers
  #27
Old 11-05-2006, 07:31 PM
CooperSAZ's Avatar
CooperSAZ
CooperSAZ is offline
Guuud Question! No idea, after I heard $6800 the rest is a blur...
  #28
Old 11-05-2006, 10:41 PM
latte hiatus's Avatar
latte hiatus
latte hiatus is offline
Originally Posted by AntiqueCarNut
I installed the IK-22's at 700 miles at a Randy Webb pulley party. He convinced me they are a good idea with a 15% pulley. Now the car has almost 17K miles. I checked the torque on the plugs at each 5K mile oil change. After installing the stock plugs. one thing that was immediately noticable, is how much easier the car starts and how much more smoothly it idles. Also, when taking off from a stop, the engine does not seem to have the momentary power lag it had with the IK-22's. I just figured this was 'normal', since the IK-22's were installed when the car was five days old, I had no basis for comparison. I can't discern any difference in power or how the car runs, other than what's mentioned above.
I'll leave the stock plugs in for now.
It's possible that after 17K miles, the IK22's were exhausted. There is a thread in the Drivetrain forum where people pulled their Densos and took photographs, and the conclusion was that the Denso iridium wore out quite fast (and are not rated 30K-100K miles, as some initial claims).
  #29
Old 11-06-2006, 09:08 PM
CooperSAZ's Avatar
CooperSAZ
I don't know about exhaustion on the plugs... Mine had about 8-9k miles on them... I'm very skeptical of the Densos now... Doubt I will ever use them again... Just cannot get excited about a plug that you have to re-tighten every 5k miles...
  #30
Old 11-06-2006, 10:57 PM
Tüls's Avatar
Tüls
Tüls is offline
Turbius Maximus
it's funny... everyone I have heard this happen to in the last few months were running densos.... coincidence...
I use NGKs... and have never had a problem... and I am running 28+ lbs of boost... if anyones should loosen... it's mine
  #31
Old 11-07-2006, 05:50 AM
AntiqueCarNut's Avatar
AntiqueCarNut
AntiqueCarNut is offline
Interesting; I will have to take a look at those threads. The center electrode and ground looked good (ie. not worn) on these and none of them seemed to be running too rich or too lean. I'll leave them out unless I see evidence that there's a significant advantage to using them.
  #32
Old 11-08-2006, 03:24 PM
kgelner's Avatar
kgelner
kgelner is offline
Just had the same think happen here - stock plugs
I just had the same thing happen to my MINI, in my case I had stock plugs anda 15% pulley - my theory is that over time the plug worked its way out and eventually blam! I don't think it blew out all at once.
I like the re-sleeve option, at the moment I am looking for something on the cheap side and a new head was NOT cheap (I had the same figures from the dealer as far as parts and labor cost). A performance head is appealing but if I can get away with a repair that saves $1k (or more) I can't ignore that as an option.
  #33
Old 11-08-2006, 07:37 PM
CooperSAZ's Avatar
CooperSAZ
Interesting... Stock plugs...
  #34
Old 02-22-2007, 08:38 PM
magic mini's Avatar
magic mini
magic mini is offline
Well this just happen to me tonight on my way home. Plug #2 blow out. I had been getting a Code that was a Misfire but didn't get time to check the plugs before this happen.
I was running NGK plugs. I Don't remember the Model Number right now but it was the ones that run a little colder than stock. By the way the stock plugs are NGK. Well in my 04 there were. Anyway I'm off to try to fix this problem.
  #35
Old 02-23-2007, 12:56 AM
Tüls's Avatar
Tüls
Tüls is offline
Turbius Maximus
what were they TQed to?
  #36
Old 02-23-2007, 04:21 AM
magic mini's Avatar
magic mini
The truth be told I don't know what they were TQed to but there were tight and shouldn't have come out. Also a note: My mini does have 111k miles on it so maybe that had something to do with it.
  #37
Old 02-23-2007, 06:17 AM
joey1320's Avatar
joey1320
joey1320 is offline
plugs shouldn't come out of heads if they were torqued properlly. this is crazy. i can't believe so many people are having this problems. good luck guys!
  #38
Old 02-23-2007, 06:25 AM
daflake's Avatar
daflake
daflake is offline
Yet another reason that I am staying stock on the plugs. The common denominator seems to be the fact that they are colder running plugs. I have seen posts with Denso and NGK both (more Denso).
The good news is that it can be repaired.
  #39
Old 02-23-2007, 06:53 AM
norm03s's Avatar
norm03s
norm03s is offline
Tüls question
I am running one step colder NGK plugs torque to 20 ft-lb w/anti-seize. Then checked again after 1k with engine cold they moved a wee bit.
What torque value are you using?
  #40
Old 02-23-2007, 07:56 AM
Tüls's Avatar
Tüls
Tüls is offline
Turbius Maximus
as Joey said... PLugs shouldn't come out... but they have to be TQed right...
I have ran 25 ft lbs as per testing since I got my car.... I say as per testing cause... using the factory spec they would get loose.. then started cranking one lb at a time.... 25 has held.... even 40+ lbs of boost... they still didn't get loose!
  #41
Old 02-23-2007, 11:01 AM
norm03s's Avatar
norm03s
norm03s is offline
Thanks Tüls
Wow 25 ft-lb is a lot of torque on an aluminum head.
Next time (soon) I check them and they move I'm pulling them to have a look. Then torque them to 22 ft-lb, I'm only making 16~17 lb. on full boost.
I was going by the Bently manual torque speck on a stone cold engine.
The NGK website recommends;
http://www.ngksparkplugs.com/techinf...300&country=US
(Wow 25 ft-lb is a lot of torque.)
But then extreme conditions require extreme measures and I'm sure NGK published data on the conservative side.
  #42
Old 02-25-2007, 10:31 AM
magic mini's Avatar
magic mini
Problem fixed. I went to Advance Auto Parts and picked up a Helicoil kit. The kit is call Save-A-Thread and the part number is 5334-14.
I put this helicoil in with out taking the head off. All I did was use a ShopVac and taped a small holes on to the shopvac and got all most all the metal pieces . The MINI is running great once again.
  #43
Old 03-06-2007, 02:27 PM
okraD La's Avatar
okraD La
okraD La is offline
At the dealer they give you a reacharound with the $6800.00 head right?
LOL...farking dealer service is smoking crack...
  #44
Old 06-18-2010, 01:13 PM
Embalmer's Avatar
Embalmer
Embalmer is offline
I had a 15% pulley and Alta cold intake done in 2005. Was advised to install colder plugs, so my tuner put in the IK22. These were in for 35-45k miles. Took in for oil, fluid service in 2008. Plugs changed to new IK22's. Oct. 2009, took off from a red light near work(after a 8 mile commute from home on the freeway). Heard a BANG, sucking sounds and all dash lites on. Was able to reinstall the plug (number 1), and drive home. Next am I re torqued all plugs to 21ft/lbs. Checked plugs every month (about 2k mi.). #1 seemed to always require about a 1/4 to 1/2 turn to torque to 21. All other plugs fine. June 1 I check the plugs. #1 just turns and will not tighten up. All other plugs fine. Take #2 plug and try to insert into #1 cyl. Just turns. Ordered a TimeSert and 2 inserts the next day. Called dealer and asked what the OEM plugs were. Was informed that they were NGK BKR6EQUP. Dealer quoted $24.99 ea. Called auto parts store, quoted $6.99 ea. My neighbor and I spent about an hour last Sunday, cut new threads, cut new seat, installed the TimeSert insert. Installed the NGK's watched as my neighbor's (Ford & Chevy guys) cringe as I torque the plugs down. So far, 125 miles on this repair, still a little gun-shy on full throttle except getting on the freeway, but so far so good. Gas mileage seems to have improved also. Total cost $220.00. Now the next question, Do I keep the MINI for another year (as I had planned) or trade now? BTW 78k miles on odo.
1lowr53
01-01-2013 04:59 PM
SpunkytheTuna
Detailing 101
08-04-2007 09:42 AM
kenchan
10-12-2005 05:25 PM
M7
11-28-2003 03:24 PM
Quick Reply: Booom!
