Crap!
Old 11-10-2006 | 08:49 AM
Dr Obnxs's Avatar
Dr Obnxs
Life is not kind...
at least not today....
So last night I got everthing back together. Including the missing exhaust bolts and even rotating the tires (car was up on stands, why not?). So everything is good. Runs nice and holds temp. Go for a test drive. So far so good. Temps holding steady.
Hit the gas.... Ooop! The dash lights up like a christmass tree, the car starts missing, and I can barly limp the 300 yards home..... Head gasket seems to be shot!
Double crap! I can do the work.... I just can't find the time! And at the consulting rates I'm booking, I may just throw in the towel and take it to a shop.... While I'm sure I could save $1k+ to fix it myself, if it takes more than a day to do I loose money!
But anyway, I'm bummed.
Matt
  #27
Old 12-14-2006 | 10:25 PM
Dr Obnxs's Avatar
Dr Obnxs
All back together!
It was cylinder #4..... But I put on a Endyn head, intake and runners. Also found out a bunch about working on the Mini engine. Pretty much everything went OK, but I learned a few tricks....
1) You can take the intake off with the SC on by taking off the engine support on the passanger side. You have to use a jack to keep the motor up, but you can get to the last intake bolt on the passenger side with a box end wrench.
2) That little 19mm bolt for the chain tensioner on the back of the block is a *****! Mine was stuck tight, tight, tight. needed a universal socket (a universal connected to a socket was too long) and I needed a pipe to extend my breaker bar! Like I said, it was tiight!
3) If you grind a bit of the intake flange by the bottom of the passenger side bolt, you can take the intake on and off more easily. That stud is a bit long for taking the intake off....
4) Thanks to El D for some timely pointers on cleaning the old head gasket and installing the new. He's a nice guy who helped me out when I needed it.
5) Thanks to Don (DMH) for some fast shipments (head bolts and some other bits).
6) These motors carbon up fast!
I started the car up today, and let it get to temp. I didn't get to drive it or feel the (I hope) new found power. When I get it shaken out (while it's all back together, I can't help but feel the bottom end has been severely aged!) I'll post impressions of the changes.
Matt
  #28
Old 12-14-2006 | 11:29 PM
TonyB's Avatar
TonyB
Matt, just saw this thread.... and I had no idea. Wow! I guess I don't feel so bad now .
Thanks for sharing what you learned. We've got rain coming, so you might want to go for a spin later tonight... otherwise, it looks like Sunday might be rain-less... Just makes it easier when hammering it....
  #29
Old 12-14-2006 | 11:58 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
Moved from Off Topic :: Autos to Beneath the Bonnet.
  #30
Old 12-16-2006 | 10:39 PM
Dr Obnxs's Avatar
Dr Obnxs
It seems to be fine!
Went for the first drive today, everything SEEMED good, but it was wet so I couldn't really see what's up. But so far so good!
Matt
  #31
Old 12-16-2006 | 10:50 PM
elprofe's Avatar
elprofe
i have one of them cooperS with no gauge How would I know it's overheating?
  #32
Old 12-17-2006 | 12:00 AM
Dr Obnxs's Avatar
Dr Obnxs
The little red light on the dash goes on....
then steam comes out all over the place!
There is a way to get water temps on the odo display. I think it's at Mini2 or motoringfile.com.....
Matt
  #33
Old 12-18-2006 | 03:40 PM
Dr Obnxs's Avatar
Dr Obnxs
You woudn't believe it....
after putting everything back togehter and doing a test drive, the coolant was low again! So I did a driveway test of going to temp with the cooling system closed up so it would get pressurized, and low and behold, all the water leaks were from the hose clamp at the bottom radiator on the driver side. What's interesting here is that the problem got progressivly worse. When I worked in that area last, the clamp was on the hose (but not far enough, for sure!) and there were no leaks. I drove for over a month before I starting loosing coolant, and when the car overheated, the rate of coolant loss was pretty good!
So, that little clamp cost me a head removal, and a water pump (That's what I thought it was originally). And a lot of aging to the motor. I was going to do the head anyway, so that's not such a big deal, but this forced the timing, and I was without a car for about a month!
Anyway, alls well that ends well. Lesson I learned was to splurge on extra hose clamps. Why reuse something so cheap that can have such bad consiquences!
Matt
  #34
Old 12-18-2006 | 04:01 PM
kapps's Avatar
kapps
Don't ya hate it when the problem turns out to be a $.50 part...
  #35
Old 12-18-2006 | 04:10 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
Good cautionary tale to us all, Matt. Sorry about your inconveniences, but thanks for the update.
  #36
Old 12-18-2006 | 04:14 PM
dmh's Avatar
dmh
The spring style hose clamps are never to be reused. We all learn the hard way. Dispose of them and invest in Wurth clamps and their nut driver.
  #37
Old 12-18-2006 | 04:21 PM
mikem53's Avatar
mikem53
Originally Posted by Dr Obnxs
I'm sitting in my car, it just overheated Boo hoo! But at least someone near by in my town has an unsecured wireless network! So at least I can post. Gotta love technology....
Matt
Seems technology would have been better utilizied by keeping your car from overheating..
  #38
Old 12-18-2006 | 04:24 PM
NMgokart's Avatar
NMgokart
Ouch! Glad everything worked out (except for the timing). Eager to hear your impressions of the new parts.
  #39
Old 12-18-2006 | 05:10 PM
TonyB's Avatar
TonyB
Matt, that's a heck of a story! Glad you are back on the road. Lessons learned, and shared with us all
XsV
24
09-30-2015 04:17 PM
riff42
09-22-2015 04:07 PM
tacticalbacon02
08-22-2015 07:05 PM
azntaiji
08-13-2015 04:24 PM
clintmeister
08-12-2015 12:11 PM
