torque wrench
#27
Get one of each. the 3/8" in a 10 to 50 lb range is great for torquing spark plugs, oil filters, etc.; while the 1/2" 50 to 150 lb range is what you need for torquing your lugs when you change wheels. Also don't forget to buy a breaker bar (1/2") and a rubber mallet for those recalcitrant lugs and wheels.
#28
I have three Craftsman torque wrenches and use all of them when working on the MINI.
3/8" dr. in in-lbs
3/8" dr. in ft-lbs
1/2" dr. in ft-lbs
I had always dismissed the H-F versions until I read on a different forum some posts by pro-wrenches who did some side-by-side accuracy testing with their Snap-on models. Turned out the $10 H-F torque wrenches were just as accurate when tested on a Snap-on calibration tool.
I also have a huge 3/4" dr H-F torque-wrench, although I've never used in on the MINI.
And never use a torque-wrench for anything other than final tightening. Absolutely NEVER use one for loosening a nut/bolt.
3/8" dr. in in-lbs
3/8" dr. in ft-lbs
1/2" dr. in ft-lbs
#29
Hi guys, thanks for all the responses. I finally drove down to Amherst and had brought a Craftsman Digitork 5-80 (44596) yesterday. I had also brought a Craftsman 25-250 (44593) today from Sears Canada which is 40% off. Will replace the spark plugs tomorrow if the weather allows. I'm sure it does, I feel like having a Christmas in Australia. It's been so warm in Toronto for late December. It's almost 7c today and there is no chance for a white Christmas at all :< :<
Anyway Merry X'mas & Happy New Year
Stephen
Stephen
#31
#34
#35
#36
SayGoodbye
The only time that you would need to adjust your torque wrench settings to get a specific torque is if you were using something like a crow foot that would extend the distance from the handle to the center of the bolt head.
Steve
Steve
EVMini
09-28-2015 10:20 AM
09-25-2015 12:32 PM
