Power steering pump fan
I wish there was another source, or at least an aftermarket solution of some different design. Despite the addition of a screen to protect the fan from sucking in object, the motor is bound to fail time and time again due to the design of the unit - the blade traps water around the motor when driving on wet roads. I have yet to find a suitable replacement in that 120mm size. It's a common size for industrial fans, but none I have found are meant for all weather usage.
Mine is Siezed...Dealer quoted $160 for the part + fgt
My dealer quoted $160...a real joke since it really is a POS!
I was going to do it myself
For $100 bucks (considering the gas and time lost traveling, and wear and tear, and time of year etc) I would have shelled it out and forgone the warranty.....but not for a rip of $160! Only thing is I want to make sure it did not take a relay/50amp fuse with it since it is completely siezed up!
I guess one could always go to an electric motor shop and have them rebuild one after warranty if needed...may the lowest bidder win when they build these things....pretty sad! Considering that if the fan screwed up in the heat...you would probably lose the expensive PS pump itself!!!
Unfortunately...
Unfortunately, if it is a sleeve bearing fan (I think it is)...it is doomed and just a matter of time....Mine is an 04 built in dec 03...This one does have the cheapo plactic mesh grill to stop stuff from getting sucked into it (supposedly) You would think they would use a ball bearing fan
Don’t know much about warranty stuff – I did replace both oxygen sensors but those failed within the first 10K miles so it was obvious it was warranty.
I went to get my new PS fan from the dealer $145.00 plus tax.
The parts guy asked if my car was still under warranty - “I don’t know” I said so he said I should check with the service peoples – they said it was warranty up to 50K miles – made an appointment and this morning they replaced the fan in less than 35 minutes – we had to wait for the parts department to open up.
All is good and it cost nothing – even got a free cup of coffee from the dealer, Sandia Mini, here in Albuquerque.
It is 2 bolts and a plug
Funny
Classic Mini=$100
yours=$145
Mine = $160
all for the same part.....ahhhh free enterprise
Anyone know how to tell if this fan has failed? Is it supposed to be on whenever the engine fan is? Mine doesn't come on when the radiator fan is running... is that bad? Also, my PS has stopped working a couple of times for a few minutes then come back on.. can this be caused by overheating due to the fan not coming on? Does anyone know what fuse to check to see if that's the problem?
Thanks!
Thanks!
may i suggest this thread for an alt.. fix or replacement fan
https://www.northamericanmotoring.co...highlight=a101
or more direct upgrade for one on the car.. is the 4 in fan
http://etxiow.accpaconline.com/searc...TOKEN=18430106
So where in the heck did my PS Pump Fan come from?
History:
When K-huevo originally posted these pics of the old and new style PS Pump Fan in the flaming engine bay thread...
...I was always feeling safe and a little smug that I had an 05/05 build date with the redesigned part.
Today I decided to remove my aluminum skid plate since I'm planning on changing the oil later in the week. While I was under there I figured I'd check out the PS Pump Fan to make sure it was free-wheeling and clear out any debris from around the bearing. Here's a picture of the fan removed, and yes indeed, we are golden as it looks pretty much like the redesigned PS Fan Pump from the front:
But when I turned it over...crap!!
This part, although cleverly disguised from the front, clearly has the same electronics (and likely the same flaws) as the early pump fans. On closer inspection, there are a few subtle differences from the front as well.
So now I'm wondering: how many months did these faux replacement PS Pump Fans get bolted on to the MINI? Does this hint that the older, more problematic wiring harness is also on board? If you have an early-to-mid '05 build date you might want to check this out for yourself.
I have this sudden, uncontrollable urge to go out and buy a fire extinguisher...
History:
Power steering humor
So I was stumbling around the internet in search of ANYTHING related to the PS (which really means Piece of **it) Fan and ran across this video from YouTube. The Mini Cooper repair manual publisher describes the difference between their two mini manuals....check out the chapter he makes an example out of.......it's quite funny...yet strange that he chose THAT chapter.
Do they know that a majority of customers buy their manual for this particular reason? hmmmmmmmm...
http://www.youtube.com/watch?v=5SQTHCZ8z1U
It's an 05/05
I was going to remove it for the summer anyway to facilitate additional air flow. My main purpose for the plate is to protect engine and drivetrain from the wintertime ice chunks that seem to breed at the end of my driveway.
Description........................ Up to:..........P/N....................Notes
Fan with protecting grille...... 07/2006...... 32416774702...... ENDED
Fan with protecting grille...... 05/2007...... 32416777632...... ENDED
Fan with protecting grille........................ 32416781742
Of course, there is probably very little correlation between the date when the supply of a particular part was exhausted from the shelf and the date when the replacement, redesigned part started showing up on the assembly line. As a result, I'm not sure the dates on this list offer much insight.
Hope you're enjoying your holiday too.
That's the $64K question.
One would imagine that there must have been some sort of perceived vulnerability in the original design in order to warrant the time and expense to change it. I doubt you could get anyone at BMW to elaborate...
I Just took off my original ps fan to clean it. I have had it off before about a year ago when my ps pump died. Had the pump replaced, but i checked the fan myself.
My fan still works, so I didn't install the SPAL replacement that I bought. I did notice something different this time when I took it off.
If you look at the last photo in Gil-Galad's post you see the fan connected to the car. On my fan, between the electrical connection on the fan body and the car connection was what looked like an extension about 3-4" long. Same connectors on the ends so it mates the fan body connector and the car connector. I noticed a lump under the heat shrink of this extension. Didn't cut it open but, from the feel of it, over an inch long and about 0.5" thick, I believe it may be a fuse of some kind.
Do you think the mechanics inserted this bit of fuse into the electrical wiring to the ps fan when they replaced my ps pump?
