Removing tranny
Old 11-29-2006 | 11:03 AM
jsf252's Avatar
jsf252
Removing tranny
As stated in an earlier post today, I've got a leak that is running down the clutch release rod and coming out around the pitman arm that the slave cylinder actuates. The slave cylinder IS NOT leaking, its something inside the bell housing.
So my question is, how bad is removing the tranny on a MINI? I've removed/replaced countless trannys on RWD cars, but never done a FWD one. Just wondering from guys who have actually done it. Do you have to drop the engine and trans to get them apart? or can you remove the tranny while the engine remains? I suspect the input-shaft seal is leaking, and lube is running down and escaping by the clutch rod. Obviously I'll replace clutch and PP while im in there.
Thanks in advance,
Josh
Old 11-29-2006 | 07:08 PM
Hound_va's Avatar
Hound_va
Old 12-01-2006 | 02:11 PM
SRICHS's Avatar
SRICHS
In that write up, that guy removes alot of things that don't need to be removed. Pretty much remove bumper to slacken front end (radiator and core support do not need to be removed) and drop subframe. After that the trans is easily removed.
Old 12-01-2006 | 02:54 PM
not-so-rednwhitecooper
Its a rather easy tranny job.
Ive dont it probably 4 or 5 times now, in and out.
Gimme a hollar if you need any help.
The_Kid
11-03-2016 07:30 PM
Crimguy
09-10-2015 02:07 PM
broncobuddha
09-01-2015 07:32 PM
09-01-2015 05:02 PM
greekzilla
08-23-2015 04:44 PM
