Jack Point Gone!
Old 12-01-2006 | 12:10 AM
mininutz's Avatar
mininutz
Jack Point Gone!
Greetings,
Has anyone had this experience? My passenger side front jack point is gone (and I can't place a jackstand underneath the car without it)... so much for my ongoing DIY modding activities/therapy. It must have fallen off (or was sheared off?) while I was driving and I didn't notice. The car is lowered, so it's more likely to scrape the pavement than a stock MINI...
I'm not sure how the factory jack points are secured to the chassis (I had assumed that they were welded on). I'm assuming that a replacement part could be had through a dealer, but does anyone know how a jack point is fastened to the vehicle?
Any suggestions would be greatly appreciated...
Dzienkuje!
Old 12-01-2006 | 12:42 AM
BFG9000's Avatar
BFG9000
The jack points are plastic blocks, and you may want to read this or this thread.
Old 12-01-2006 | 12:50 AM
mininutz's Avatar
mininutz
BFG9000, thanks for this tip. I had no idea that they are plastic! Doesn't inspire confidence...
Old 12-01-2006 | 01:15 AM
afnos's Avatar
afnos
2 of mine are missing, too. I just place the jack where the pad used to be.
Old 12-01-2006 | 05:16 AM
umberto's Avatar
umberto
Also, I have heard that using the front jack point you can lift up both the front and rear at the same time to rotate the tires.....is this really safe?
Old 12-01-2006 | 05:31 AM
rivet's Avatar
rivet
Check out Texas Speedwerks. They make low profile replacements. Better than oem and very good quality.
http://www.txwerks.com/servlet/Categ...%3AJack+Points
Old 12-01-2006 | 05:45 AM
IanF's Avatar
IanF
Yes. Thanks to the exceptional rigidity of the MINI chassis.
Old 12-01-2006 | 06:24 AM
mikem53's Avatar
mikem53
Actually.. its thanks to the short wheelbase and jacking position..
Old 12-01-2006 | 06:27 AM
gizzer777's Avatar
gizzer777
Very Common
Originally Posted by mininutz
Greetings,
Dzienkuje!
The Jack oem blocks are really cheap(about $8) and are always falling off. They are held in place using a simple plastic snap in type plug....The dealers usually have em in stock but it is a minor PIA.
Old 12-01-2006 | 06:36 AM
Chappy's Avatar
Chappy
Greetings,
Dzienkuje!
Check this out:
https://www.northamericanmotoring.co...ad.php?t=82532
COR BLMY started a new thread on this today:
https://www.northamericanmotoring.co...=1#post1249968
Mike
Old 12-01-2006 | 06:37 AM
gizzer777's Avatar
gizzer777
A wee bit expensive ...BUT NICE
They look really nice but $100??? I do not think so, Why is everything for Mini so expensive? Since you would not jack the MCS (Maybe for an MC w/ spare) up to chg tires on the road...only in the Garage, I use a 2x4 for garage jacking or to work under it, I use a set of Rhino Ramps, then Jack stands just to make sure...Might make an extension so I can use my regular HD steel ramps which raise it higher, but right now, the Mini will not make it up on them without the front air dam hitting....and mine is stock height on 17" rims...
Think I will be installing a Fomoto oil drain plug valve on it next oil chg so I can just flip the spring loaded lever to drain the oil...It has just been sitting around the garage and it's time. The exact same one that fits my 05 element, also fits the mini oil plug...gets rave reviews! Getting too old to be creeping under the mini (and my belley is still flat too, so it is not the problem!)!
Old 12-01-2006 | 06:56 AM
IanF's Avatar
IanF
Not necessarily... have tried the same method on a Spitfire... which has an even shorter wheelbase than the MINI... but has the chassis stiffness of a wet noodle... results are... not the same...
Old 12-01-2006 | 07:15 AM
mininutz's Avatar
mininutz
Thanks to y'all for the input! I've contacted Jayson at Classic MINI and I'm getting a replacement (about $7 with NAM discount, regularly $9). Heck, while I'm at it, I think I'll order a couple spares.
The texas speedwerks units look good, too, though. I like the idea of a metal jack point when I'm under the car! Probably worth every penny...
Old 12-01-2006 | 08:11 AM
gizzer777's Avatar
gizzer777
Suggestion
Just a suggestion...Get a set of jackstands ...Cheap insurance. I learned years ago never to get under a vehicle help up by any type of jack alone! Luckily it was not me!
Jeck er up and put the jackstands in place....safety!
Old 12-01-2006 | 09:18 AM
mininutz's Avatar
mininutz
Hi Gizzer,
Actually, I am using jackstands... sorry if there was any misunderstanding. The problem is, without the jack points, there is no place to put a jackstand.
Also, the factory jack points are not designed for use with a conventional floorjack or lift. There are direct contact points on the chassis for actual lifting.
Old 12-01-2006 | 10:28 AM
gizzer777's Avatar
gizzer777
Good deal
Hi Gizzer,
Glad to hear you are using the stands!!!
I use a 2x4 block (that I shaped) at the jack point to chg tires and a low profile floorjack....works fine, then the Jack stands go under...I do not like those cheapo plastic things...and while nice, the Texas speedworks blocks are too pricey for the number of times I have the Mini up (I do not track it). Have the ramps as well so I am good to go.
Regards
jeff
Filmy
15
06-06-2023 07:27 AM
asmasm
08-18-2016 10:34 PM
gnhovis
12-14-2015 06:31 PM
Fordgt4
10-10-2015 11:42 AM
TurboMike
New York/New England
09-28-2015 09:12 PM
