MINI Cooper Midland Transmission Failures
On the contrary, I have always heard that there is a faulty seal that will let all the fluid slowly drain out of the tranny, and that causes the failure. I don't know that the real internals are shoddy, just the stupid plastic or rubber seal that likes to fail, especially in extreme cold.
Well, no, it sounds like you are right then. If the fluid levels were fine, your failure had nothing to do with faulty seals. Very disconcerting for me and my Midlands. But I am at 22,000 miles and going strong. We'll see how it goes...
Platic bearings/seals is part of the problem, loss of drive on the diff due to the outer ring separating, weak syncros on 1st and 2nd.
Yup. It sucks alright.
I was lucky enough to have mine garnade 1 month and 1,000km after my warranty expired.
http://www.minimaniauk.com/web/Item/.../InvDetail.cfm
This gearbox might be a better idea then getting another Midlands. Outer ring is modified by adding dowels and is spot welded, uprated syncros and output bearing with a metal race is also used.
I heard you can use the Getrag 6 speed but I'm not exactly sure if fab work is required. I think Steve's Auto Clinic in L.A. did it.
Hope that helps.
Randy
Hope that helps.
Randy
Details on this NAM thread:
Cold weather Blown Tranny...
Although not limited to cold weather entirely. Basically, the outdrive bearing seals crack (earily models were pastic! ), and the tranny fluid leaks out. If you catch it in time through regular inspection, the service runs in the $200 range-- don't quote me on that tho. If you're too late, meaning you've run the tranny w/ low are no fluid, the bill will be closer to $4600.
The link above gives helpful insights on the noises of lost trannies. From what I've seen, the noise makers are the expensive ones. Mine was a noise maker too.
Good luck.
Good luck.
Yes, it was me. I'm on my 3rd tranny and 2nd clutch. And guess what started today? A clattering from under the driver's side engine mount. Goes away when the clutch is in. Sounds like a throw-out bearing. I have an appt. for it to go in Tuesday.
All this sounds like I'm a horrible driver and tough on my trannies, doesn't it? I'm not! I'd like to think that is because I can drive a stick better than anyone else I know is what kept my Midland going so long. In the end, that probably screwed me too. As for the MINI I have now, she's just a lemon. I love her to bits, but a lemon none the less. I have managed to get almost 4K more miles on her before the throw-out bearing went out. She now has 6,900 miles on her: 3 trannies, 2 clutches, 2 A/C compressors (oh, did I mention that needs replacing again too?), and the rear control arms squeek like a mattress in a cheap motel. I haven't even autocrossed her yet!
Extreme cold is the number one killer of the Midlands 5-speed. Well below zero. I've had two fail so far.
Autocrossing and track driving don't seem to bother the gearbox that much. Perhaps drag racing would put too much strain on it, but other than that, no problem.
Just leave the car sitting outside when it's well below zero, and one of the seals will fail, the fluid will leak out, and the gearbox will fail.
I was told the the second replacement I got was a redesigned seal that will hold up better to the cold. It made it through the last Vermont winter, we'll see if it makes it through this one too.
phrza81
10-10-2015 11:37 PM
08-07-2015 05:55 AM
08-05-2015 02:11 PM
