'04 MC sluggish when cold
I have an '04 MINI Cooper. No issues with the car except that when it is in the 30s F, (it hasn't been any colder yet), the car is a bit sluggish when I start out. No problem with idle, but when I hit the gas, it sputters some for about 20 seconds. It has 34K miles. Could it be a cold start problem?
Thanks,
David
Thanks,
David
The owner's manual states "not to let the car warm up in the morning", but rather to drive away....slowly. Are you doing this, or just racing off? If so, that's bad. Let the car idle for at least 2 minutes, then slowly drive the car away. In a few minutes the car will be to operating temps and you should be good.
I don't think I've ever owned a car that hasn't been sluggish on a cold morning. Engine is cold, fluids are thicker, I think it's just a normal thing. I can tell you that I'm definitely sluggish on a cold morning when I wake up. I idle in a hot shower for at least 10 minutes before I hit the gas and speed on to the rest of my day.
I have noticed problems with my '05 being sluggish in the AM this winter too (I'm in the South so it's not that cold). It goes away pretty quickly but it is a biatch because my driveway is on an incline & I sometimes have to pull into traffic so I need a bit of gas.
It's been in the teens around here lately and my Mini seems to be taking it like a champ. The dealer in San Francisco did a software update to the engine controller before I shipped the car to Alaska. They said it should take care of any cold start and driveability problems that was supposedly a problem w/ the older software.
As per the manual, I drive away, not subjecting the car to any sudden bursts of acceleration. Doesn't seem to take long to warm up despite the weather, and so far - no cold weather issues.
Not so sure about running anything less than premium though. I don't think I'll try it unless I start having driveability issues...
91 is the way to go
My manual says to use nothing less than 91 octane so I use premium.
My '04 MC has always had the "bog" on cooler mornings when shifting from 1st to 2nd.
The car starts great and idles fine, but that initial shift to 2nd has the same effect when cold, feels like the car will stall. It never has stalled, but it's kind of annoying when the stumble occurs. After the first stop sign near my house (maybe 3 blocks) the next 1st to 2nd shift it happens again but not so forceful. After that everything is fine.
Just had the Inspection 1 completed this week and no difference. (27,000 miles)
Consider it a "feature".
Colt45Magnus
10-01-2015 04:08 PM
10-01-2015 12:13 PM
