Exhaust Leak
Exhaust Leak
heyo guys
i was wondering, does anyone know of some kinda sealent I can use in between some exhaust flanges?
I tried the copper sillicone, but its only rated to 700 degrees (pssht, that lasted a day)
I'd really rather stay away rom that muffler putty as its really hard to get off when you need to.
any ideas?
any ideas?
I actually had temporary luck using some crumpled metal foil rolled and shaped into a round crushable "gasket", but my "gap" was only 1-2mm. I'd go with the stackable gaskets theory, but if you have access to a Bridgeport and will be pulling the exhaust anyway, just go the extra 1/2 hour and be done with it. Good luck either way!
Wait a minute
What caused it to warp in the first place? Are you using fat washers under nuts or bolts against the flange to spread out the load?
If you mill it flat you may see it warping again because it's thinner and even more prone to warp.
Its warped because I tried to weld a 3 inch pipe to a flage that came of of a 2 inch system, the welds ran to the edge of the flange and got too hot before I noticed.
Its the flange on the front of the exhaust where it meets with tie header.
i'll see what happens with a few new gaskets today.
I'm usually not too keen on using stacked gaskets, but I guess I could give it a try and see if it holds...
Could you have the flanges milled down at a local muffler shop or machine shop. This would be like starting fresh. You could have the matched perfect and then hopefully the gasket will work.
Mario
Mario
gmonde
09-08-2015 06:37 AM
