Battery/Electrical Issue
I went to get into my car. MCS, last night after tennis. I was walking up to in from behind, and hit the boot unlock button. Nothing happened. Tried again, nothing. I tried to unlock the entire car by hitting the unlock button twice. The driver’s door unlocked, but not the boot. At this point I’m concerned about the car starting, so I try starting the car. The car starts fine. But I notice that the backlighting on the radio, A/C, and toggle panel quickly dim and go out. Strange! Everything works, just no backlighting. And then suddenly, the boot unlocks!! I get out and close it, and drive home. No issues, just no backlighting. Try everything again after getting home. Same behavior. I hooked up my battery charger, and it said fully charged. Still acting the same this morning.
Battery issues? Other known electrical issues?
This sounds like it could be a grounding issue. There have been isolated cases of this happening, it usually shows up in a cluster of features not working properly when other things work fine. There are multiple ground points around the car that 'collect' wiring from a number of circuits nearby, and some might not make full contact, causing a group of them (rahter than a single one) to act strange. Also, there is our famous body control module that is responsible for running most of the systems in the car. If it gets a glitch in it, strange things can happen (or not happen at all for that matter).
Sounds to me like it could be a warranty issue.
09-01-2015 04:02 PM
