Weird thing happened...
Old 05-04-2003 | 08:03 PM
kapolani's Avatar
kapolani
I started my car up. I was trying to put it in reverse so I could back out of the driveway - I couldn't get it to go into reverse. I tried a couple times. I finally ran through all the gears - 1st, 2nd, and so forth. I was finally able to get it into reverse. It seems to be fine now.
What do you think happened?
Old 05-05-2003 | 11:36 AM
Moorlockx's Avatar
Moorlockx
It could have been a couple different things... none of which you want to get involved in. If it's not a major drive, take it by the dealer and have them check it out. If they can't find anything, at least you'll have it on record that it was checked in case it decides to happen again.
Old 05-05-2003 | 11:39 AM
Davbret's Avatar
Davbret
Syncros were off. Could have just put into neutral and then depressed the clutch, thereby resetting syncros...just in case it ever happens again.
R
patsum
26
05-29-2021 07:29 PM
Sc00terbum
09-11-2015 08:17 AM
HogWldFLTR
09-08-2015 06:25 AM
Ladybug-S
09-01-2015 08:07 PM
