Strange new vibration
As of this AM, Basil has developed a driveline vibration. It feels like a high-frequency "ratcheting", similar to ABS kicking in, but milder.
It seems to be engine related, as when I declutch and coast, I don't feel it.
Also at the same time, my boost gauge has gone a bit wonky.
Where previously I would run ~8-10 in/hg at freeway speed, now I'm getting 2-5 in. Also, very quick to go to boost at the lightest throttle application.
I'm guessing the BPV may have something to do with it, but that's just a guess.
Help?
Help?
Bryan, thanks for the reply. The vibration is felt, more than heard, through all points mentioned. Also seems constant, not RPM-variable, but I could be mistaken there. I'll test it some more today and try to pin it down.
I did recently change tires to non-RF, but have ~600 miles on them before this popped up.
i thought i was going crazy mine started doing that recently, and i thought it was tie-rod ends but it makes no sense that when accelerating it stops, but when i let off it starts again and if i am at a constant speed such as flat ground and cruise control it does it but only right around 90 mph or so?
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
