Help, I mistakenly put regular gas in my Mini.
Old 08-05-2003, 06:46 PM
6f7's Avatar
6f7
6f7 is offline
Do not use low octane gas. We just replaced the entire head on a MCS after the owner repeatedly filled up with 87 octane. It can really do some damage.
_________________
  #27
Old 08-06-2003, 01:58 PM
miniwanna's Avatar
miniwanna
miniwanna is offline
Don't worry about it. Use premium next time if it makes you feel better. A lot of the European cars imported into the U.S. state that they must use higher octane fuels. Even the higher compression cars like the Minis are unlikely to pre-detonate on the low octane regular fuels found in the U.S. The compression ratios of these cars is not nearly high enough to notice the diffference between the 87 octane and "premium" 91 octane fuel. One difference is that in Europe some of the sub-90 octane fuels are leaded or low-lead fuel and these fuels are not recommended at all for use in Minis. Since these fuels are not available in the U.S. its not a problem.
One difference is the higher octane fuels are slightly cleaner burning and all the emission standards the cars must pass for import are performed while running premium fuel, which is why I believe they recommend 93/94 octane fuel. So let yor environmental concerns be the guide for fuel selection if that's what appeals to you. I doubt the small difference in octane will change the mileage or performane in any noticeable way.
  #28
Old 08-06-2003, 02:04 PM
minihune's Avatar
minihune
minihune is offline
OVERDRIVE - Racing Champion
Open the gas tank lid- let the gas evaporate- check each 3 days by starting the car to check on the progress. Then refill with the better stuff.
Or add some moth ***** to the botched tank of gas to increase the octane.
Honestly it isn't a big problem at all. But my MINI always gets the good clean higher octane stuff. Better performance and better gas mileage, cleaner running-less dirty innards.Maybe longer engine life.
  #29
Old 08-06-2003, 02:11 PM
2minis's Avatar
2minis
2minis is offline
I used regular one time and the monkey spanked me.
  #30
Old 08-06-2003, 02:39 PM
Xanthus's Avatar
Xanthus
Xanthus is offline
Coordinator :: South East - Florida
I was thinking of Jet fuel........J/K
  #31
Old 08-06-2003, 03:01 PM
mcs22004's Avatar
mcs22004
mcs22004 is offline
Gasoline distributors would get a good laugh out of this thread.
  #32
Old 08-06-2003, 03:03 PM
ToeKneeC67's Avatar
ToeKneeC67
ToeKneeC67 is offline
I did this to my parents Honda Accord. Physically there was no damage. But the timing was off when the spark hit so after a while the car died. My only advice if the car is running still is to keep topping it off with unleaded.
  #33
Old 08-07-2003, 05:33 PM
Red's Avatar
Red
Red is offline
Great advice! Of course, I doubt if the car is still running. They would have run out of gas by now. And where can you get leaded gas these days?
:smile:
Regards,
Red
  #34
Old 09-22-2019, 11:17 AM
ericJR's Avatar
ericJR
ericJR is offline
Originally Posted by Azwed
Yeah you can get both leaded and unleaded 100 plus octane racing gas near just about any dragstrip/circle track.
Note that if you run leaded gas in a car with a catalytic converter, you will destroy the converter. In the process, it will become extremely hot and possibly cause your car to catch fire.
  #35
Old 09-22-2019, 02:06 PM
tlhamon's Avatar
tlhamon
tlhamon is offline
In all seriousness, I read an article in one of the car mags where they ran 87 octane in cars that required premium gas (one was a BMW, there was a Dodge Challenger, etc.) and their biggest takeaway was loss of horsepower. I don't remember anything about sparkknock just that the cars don't perform as well as they can without the extra octane. So, no danger in it short term at least.
  #36
Old 09-22-2019, 03:00 PM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
resurrection of a 2003 thread . . .
  #37
Old 09-23-2019, 01:24 PM
pnwR53S's Avatar
pnwR53S
pnwR53S is offline
6th Gear - NAM Hall of Fame
Digging for some life in the graveyard forum, and all could be found are some long buried skeletons.
Alkaidovich
01-30-2021 01:35 AM
07-16-2020 12:54 PM
minipopkart
08-13-2015 05:22 AM
dchang0
08-10-2015 03:37 PM
WayMotorWorks
08-04-2015 01:47 PM
Quick Reply: Help, I mistakenly put regular gas in my Mini.
