P0108 Code - definitive causes?
Old 03-29-2007 | 05:46 PM
minimc's Avatar
minimc
P0108 "Manifold Absolute Pressure/Barometric Pressure Circuit High Input"
Car goes in for various work. Dealer calls & says their scan tool is detecting intermittent Tmap/map sensor errors. He chooses to replace both the Tmap & map sensors.
I get the car back, go for my first drive. Feeling a bit frisky I bring the revs to 6750 - engine light comes on. I drive back to the dealer & have the fault code read: P0108.
I'd never had this occurrence prior to replacement of said Tmap/map sensors. What are the odds that I went from not great to bad or worse?
Does this sound like defective T/map sensor(s)? & How common are faulty sensors?
Old 03-30-2007 | 03:50 PM
minimc's Avatar
minimc
BUMP
Old 03-31-2007 | 07:32 PM
90STX's Avatar
90STX
I'd say it probably isn't common. The only times I've heard of folks having that fault code are when they are running small pullies (mostly 19% or a similar ratio of the crank/supercharger pullies) or otherwise higher boost levels.
If you are under warranty, I'd say you'll need to make another trip back to the dealer. Good luck.
Scott
90SM
Old 03-31-2007 | 11:16 PM
minimc's Avatar
minimc
Scott
90SM
Thanks Scott
Interestingly the car's only got a 15%... no other significant mods (at the mo')... so dunno where the this could be comming from... just ODD. Being that (I assume from your comment) you've run into or heard about this fault with 19%, can you tell me where?... Was it in a thread here, or personal experience or through an aquaintance?
TIA
Old 04-01-2007 | 07:06 PM
90STX's Avatar
90STX
Personal experience with a 19%. I just clear it myself using the Scangauge II. If that is the reason the code was thrown, it should also clear itself after three restarts.
Scott
90SM
Old 04-02-2007 | 02:52 AM
MINI-Bee's Avatar
MINI-Bee
I have a similar problem. Every time I hit a certain mph my light comes on. The code is P0108, both times. It has done it twice now and at the same speed both times. But after 3 restarts it clears itself, although the code still stays in the computer. I am running a 17%, miltek cat-back, and ALTA CAI. Does anyone know exactly why this light comes on? And if there is a way to fix it so it won't come on?
Old 04-06-2007 | 07:39 AM
MINI-Bee's Avatar
MINI-Bee
Hey all, I talked to Helix about this code. According to them it is an overboost code. When your supercharger hits 18psi or more this code will come up. And after 3 restarts it should go away. Now that is only one reason why this can come on (I am assuming, if I am wrong in doing so someone please let me know.) I am sure that if you have a problem with the MAP sensor or some other sensor then this code will come on and stay on.
Old 04-07-2007 | 01:31 PM
herbie hind's Avatar
herbie hind
so for a 15% 'er you're making great booooooooost!!!
Old 04-07-2007 | 07:59 PM
MINI-Bee's Avatar
MINI-Bee
I am running the 17% but if this is truly what is causing minimc's problem then yes he is making AWESOME boost for only a 15%!! But if I were him I would still double check that it is NOT a TMAP sensor and any other sensor problem.
Old 04-12-2007 | 09:07 AM
minimc's Avatar
minimc
That... or I've got restriction within the system, and my s/c is effectively attempting to inflate the intake manifold, like a balloon .
Old 04-12-2007 | 02:41 PM
herbie hind
nice visual
carid
09-02-2021 07:22 AM
thadscottmoore
06-04-2021 07:19 AM
NHcountryman
09-06-2015 11:01 PM
Richard Kellstrom
09-04-2015 07:21 PM
Quick Reply: P0108 Code - definitive causes?
