Oil drain plug
#52
I don't really know what the deal is with the drain plugs seeming like they have been welded on. We have two Mini's on which I change the oil every 5K. The dealer manages to get in there once in a while as well, and the plugs don't come out easily after they change the oil. After fighting (and succeeding) to get the plug out on my car with the help of an impact screwdriver, I installed the valve. However, on my wife's car, nothing I tried worked to get the drain plug out. I had such a little nub of the bolt head left that I really thought I would have to remove the pan. However, at coffee one morning, a buddy reminded me of an old shadetree trick, which worked REALLY well. Drive the car till warm. Put it up in the air so you can crawl under with a handful of ice cubes. Press an ice cube against the drain plug but nothing else. I tried the plug after 2 ice cubes and it came out like it had never been tightened. Still - I put the drain valve on this car as well...
Let me know if this works for you.
Pat
Pat
#53
The ice cube is a great idea.
I understand and support your comment, but mine still rounded with a 6 point 13mm Craftsman socket, firmly held on by pushing against the wrench. With the 19mm VW plug (which I already owned, so it was free) - no issues. Looking for a Fumoto one of these days...
And folks, if you do not have the proper tools to remove the drain plug, don't.
#55
Every time I have removed one of those drain plugs & I've done a few, they are TIGHT. Even the one on my car that I am very careful to not over tighten. I'm sure it is that washer causing it.
My method is to put my wrench on & give it a sharp tap with a dead-blow hammer. Works every time for me.
I like the Fumoto valve, it seems well made, but I can't get over the fear of snapping it off with disastrous results. I track my car occasionally & worry what the race track curbing would do it if I straddled a curb.
That 19mm VW plug seems like a great idea. Next time I'm at the parts store I'm picking one up along with a bunch of crush washers.
#56
#57
#59
Note that the VW plug is maybe 1/8" longer (into the pan) than the Mini plug. Since I haven't seen the inside of the Mini pan, it was relatively easy to grind 1/8" off, hyper-clean the plug, and go from there. I doubt it was necessary, though.
An interesting addition is that VW plugs are available with those powerful magnets in 'em. While I have my doubts on their overall effectiveness relative to the oil filter, I can say that I get some black ferrous gunk off the one in my wife's VW every now and again.
Note too - with the aluminum skidplate, the oil plug is quite well protected. I have not seen the Fumoto on a Mini with a skidplate, but the plate would likely protect it quite well also.
#60
(I replaced it with a generic plug - which extends MUCH further - instead of drilling/tapping for a helicoil. But I miss my oil temp.)
#61
#62
Fumoto's direct source:
http://www.qwikvalve.com/
once you put this on you never remove the plug to drain oil - just flip the lever
#63
Thanks just order'd one off fleabay $25,what's your recomendation for repairing the threads in the oil pan helicoil?What we've done for a temp fix is longer bolt it's got some threads left so it went up and is not leaking but i want to do a proper fix.Thanks for the reply Capt,i've had this baby from new 2003 and love it can't bring myself to sell it after modding suspension and brakes ages ago,just a really fun little car to drive.All the mods i did were compliments of you guys on here and all were spot on.
#64
well given that you've ordered the 'proper' size, a coil insert is a way to go assuming you don't want to bite the bullet and replace the pan for a 100% correct fix. Had you not yet ordered the Fum' tho, I'd have eliminated the insert step by researching the QwikValve site a bit and just ordering a larger diameter valve, tapped the pan - exactly as you will for the insert - and used an oversized valve . . . one less thing to go wrong....
If you can get the Fum' to 'bite', I'd be tempted to just JB-weld it into the pan for a brute force fix. After all the point of the valve is not needing to pull it off again . . .
#65
I finally got the Fumoto. With the skidplate that sucker's really well protected. The only "issue" (if you'd call it that) is that it extends the oil drain 1/2" toward the rear of the car, and with the car on ramps the oil can get on top of the skidplate. Fix? Use a small square of aluminum foil and redirect the oil flow downward. Done. Wouldn't go back, and that sucker's not opening unless you want it to.
I'll have to dig up that 19mm plug and throw it on the marketplace, don't remember where I put the darned thing!
#67
#68
#70
Ditto to the Captain! He was the one that tried to get my oil plug out!! Finally took it to a friend who is a professional mechanic and he had to use an impact hammer to get it out. Those MINI technicians really put it in there good.
Bought the Fumoto Valve for both MINIs and no more problems with getting the oil plug out. It is worth every penny.
08-19-2015 12:51 PM
08-19-2015 08:27 AM
