Oil plan plug stripped!!!
Im not really sure where this thread belongs, but ive got a problem... So i just get ready to change my oil, my warranty ran out in jan so this is my first time doing it on the MINI myself, i have the car jacked up, got my 13mm socket ready to go and dove under for a quick pull and drain. not so much... as i place the 13mm onto the bolt i realized it was stripped... completely... does anyone have any idea how to save me on this?!?!?! please anything... thanks in advance
You mean the HEAD of the bolt is stripped, the BOLT threads are stripped or the PAN threads are stripped?
If it's the head - that's easy. A pair of vice grips should suffice. Buy a new bolt before starting.
If it's one of the latter two (or both) then you either helicoil, or replace the pan.
I'm hoping it's the first.
In case some time you ever get buggered threads, there are oversize plugs available. I know Pep Boys, AutoZone, Napa carry them. They're slightly oversize and basically cut new threads. They have multiple steps between the normal bolt sizes.
You could end up with them without even knowing it if a shop or dealer changes oil (and doesn't bother just putting the bolt in anyway and sending you on the way).
One reason I tend to do it myself even while under warranty...
1)BIG vice grips, clamped down tight
2a) Big pipe over end of vice grip
or
2b) BFH (Big Freakin' Hammer) applied judiciously (lefty-loosie!)
2a) is probably the more efficatious method
2b) might make you feel better after all the frustration
Another alternative is to grind down two flats on the edge of the bolt and use a big adjustable wrench.
or
Glenns0245 -
Now that you can get the plug out, order a Fumoto valve and you never have to worry about a stripped bolt or pan threads again.
http://www.fumotovalve.com/
I put one on my car 2-oil changes ago and it made life a breeze!
T
T
07-16-2020 12:54 PM
ebowling
90
08-04-2019 09:15 AM
