Engine Cooling Fan is Cycling
Aloha! Hey, my 2005 MCSCa has about 24K miles on it. Just noticed that on a moderately warm day with the A/C on, the underhood cooling fan cycles on and off. The fan remains on for 15 seconds then shuts off for 10 seconds. The timing doesn't vary and the gauges don't show any overheating. The cycle continues to repeat itself and sometimes I notice that the cabin A/C fan slows down for a bit then picks back up.
Any ideas before I hit the dealer?
on
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
You get a new coolng fan or a aftermarket replacement for the failed resistor on the cooling fan...
Short cycling of the highspeed fan is caused when tye resistor faoled, rendering the low speed portion of the fan inop....
Very common...a large % of gen1 mini's do/have had this issue.
Buy a new cooling fan!!
Many/most gen1 mini owners have had this issue...it is likely the member that posted this has long since sold their car...look how far back they were last active.....his last post was 2006.
Or do this:
https://www.northamericanmotoring.co...olution-5.html
By getting this:
http://ph.mouser.com/ProductDetail/A...XjsYM7uQ%3d%3d
or:
http://www.detroittuned.com/shop/?productID=530
Cheaper & you get to retain your OEM fan til it finally waves the white flag.
By getting this:
or:
Kimolaoha
07-05-2023 01:04 PM
