Engine Problem
Old 04-24-2007 | 11:06 AM
harhoosh's Avatar
harhoosh
Engine Problem
I have a small Question:
If you open ur oil engine cap.. and there is a air presure.. that means that there is sumthing wrong with your engine right ???
even my fan keep running between time to time.. but my engine temp is normal .. wut do you think guyz
Old 04-24-2007 | 12:32 PM
Yo'sDad's Avatar
Yo'sDad
Are you talking about opening the oil fill cap while the engine is running, or turned off?
Your cooling fan is controlled by a T-stat in the lower radiator. It can come on even with the key in your pocket... so be careful... this is normal.
YD
Old 04-24-2007 | 12:40 PM
Guest's Avatar
Guest
I'm not sure pressure after releasing the oil fill cap has means anything is wrong. It's normal for the system to build pressure.
As for the fan, the fan does indeed run whenever the coolant is hot, regardless of whether the car is on, off, etc. The water temp gauge in the car functions only when the car is overheating, or cold. It doesn't move at all basically unless your car is about to overheat and steam is shooting out from under the hood, or the car is ice cold because it's been sitting all night.
Old 04-24-2007 | 03:33 PM
herbie hind's Avatar
herbie hind
that's just blow bye . while at idle it should be very low though . if it feels like something you havn't experienced with another car , then it's time for a compression test .
Old 04-24-2007 | 10:05 PM
harhoosh's Avatar
harhoosh
Actually there is pressure while the engine is running.
and regarding the fan ..
do you think the t-stat need to be replaced ?
Old 04-25-2007 | 07:49 AM
Yo'sDad's Avatar
Yo'sDad
Positive pressure when running is normal.
No, the t-stat is fine unless you are overheating.
I suggest that you start reading some books on how you engine works.
YD
Old 04-25-2007 | 08:08 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
All 4-cylinder engines create an pulsating crankcase pressure that will show up when the oil cap is removed when the engine is running. This is normal. To test for positive pressure, place your hand over the oil fill opening. You should not feel either an increasing pressure or vacuum. You will feel the pulsations though. Do not do this with a hot engine, however. Ouchy-ouch can result from hot oil.
Old 04-25-2007 | 11:10 AM
harhoosh's Avatar
harhoosh
thx guyz.. u make me feel happy.. i was thinking on this this issue from last night..
Old 04-25-2007 | 03:16 PM
herbie hind
i looked at a 96 mustang 4.6 a while back and if you pull the oil cap off the rpms changed drastically . also when i pulled the pcv tube off the pcv there was zero vacuum to the intake tube . i walked away . it's like the intake was buggered or something .
Old 04-25-2007 | 10:43 PM
harhoosh's Avatar
harhoosh
can anyone check his mini.. and try to remove his oil cap and check if there is any pressure ? and answer me back : (
Kimolaoha
07-05-2023 02:04 PM
alistaircookie
10-08-2015 11:52 AM
Zettinger
08-25-2015 05:04 PM
Mini Cooper r56 Pr
08-12-2015 08:42 PM
08-12-2015 02:24 PM
