Suspension THUMBS UP to Ireland Engineering camber plate
I got a fixed front camber plate installed two days ago. That evening I went out for a driving, on a local back road, the turn-in is definitely better and the front end bites nicely. I can rotate the car much easier now in mid-corner.
For $180, I think it was worth the upgrade.
We did a test run on this offramp. My passenger say I was able to maintain 50mph and 55mph on the exit..the posted sign is 25mph if I am not mistaken.
link to offramp..
http://maps.google.com/maps?q=Duarte...&t=k&z=18&om=1
so far..the best upgrade I have done to the car thus far, beside 225/45-17 Falken Azenis.
link to offramp..
PM me with a price, If you sell i'd scoop them up if they are at the right price
I liked these as well. Really helped the car but if I was going to do it again I would get adjustable once. The fixed plates from IE gave me two driffrent camber ratings. Driver side I was at -2.05 and Pass. side I was at -1.75.
To some its not a big deal but I would prefer adjustable once and just set them at even on both side.
Tires should wear more evenly with more negative camber... Unless you never make any turns.
If you push harder through turns, you'll want more negative camber to keep more tire on the ground, which will improve tire wear.
The more gentle you are with your car, the less negative camber you'll want/need to run. A ton of negative camber on a car that is never pushed hard will cause the tires to wear unevenly.
Saw the thread so i thought id chime in. i just got these from my fiancee earlier this year and had em installed before xmas. Turn in is nicer, tighter, smoother and the ride is a little firm, but not bad at all. Definately a great relief knowing i wont have to worry about the strut tower mushrooming which is the prmary reason i got these. So far NOOO problems and im enjoying the heck out of em!
ebowling
90
08-04-2019 09:15 AM
Minibeagle
08-13-2015 10:00 AM
ClayTaylorNC
08-10-2015 09:19 PM
