Suspension OMP or Madness Lower Brace?
Old 04-18-2008, 08:57 AM
newbs49's Avatar
newbs49
newbs49 is offline
THE ITCH
Steve
Any thoughts on the bar you added to your GP. More understeer. Less body noise? Track season coming. Need a little help.
  #52
Old 04-18-2008, 03:50 PM
THE ITCH's Avatar
THE ITCH
THE ITCH is offline
Larry
I haven't had a chance to clock too many miles on some of my favorite roads but my first impressions are very good. Mind you I did add the Madness bar and the Cabrio braces over the winter so the resultant is of the two installs.
I noticed some added understeer and increased the Web bar another notch. I will play with that a little more once I get some time on the setup. Roads here have just this week gotten above 50 degrees so I have been cautious.
There have been some very noticable diferences in the attitude of the car. There is definately less noise in normal driving. It appears that the bar or bars are allowing the struts to do their job more effectively. Going over expansion
joints in the pavement is hardly noticeable now. Also the car feels more planted on uneven pavement while aggressively cornering.
Larry I'm pretty sure you will like the changes and for the dollars spent it is IMO well worth while.
Steve
Originally Posted by newbs49
THE ITCH
Steve
  #53
Old 04-18-2008, 07:11 PM
oxtox's Avatar
oxtox
oxtox is offline
more stable yes....but more understeer. finally getting around to taking the bar off tomorrow. i'll drive around and post back.
  #54
Old 04-18-2008, 09:32 PM
ED955S's Avatar
ED955S
ED955S is offline
I tried the softest setting on the sway bar and yes indeed it gave more understeer and it will probably more felt in less stiff tires or higher sidewall profile. My GY RSA runflats have worse turn-ins than the OEM 17" Dunlops or Pirellis. I found this out during the Mini Test Drive event in Vancouver last 2005. It was a mistake to chose the GoodYear all season when my dealer asked me what tire I want as I don't drive my MCS during winter anyway.
I too would definitely suggest to go on stiffest setting on sway bar if underside brace is installed.
  #55
Old 04-19-2008, 08:54 AM
oxtox's Avatar
oxtox
oxtox is offline
funny, my dunlop direzza star specs (uhp non runflats) came in yesterday and were put on this morning. went on a test drive and immediately went into "hold everything" mode!!! it drives fantastically now . so i will not be taking the omp off for now and have my 19mm rear bar at it's stiffest setting. i'm thinking camber plates/coilovers with this set up would be crazy good. my run flat gy rsa's just couldn't hold the road as hard as i was pushing the mini. i hope they'll be servicable as winter tires....but i'm doubtfull . now everything feels real nice ....just in time for tomorrows autocross!
  #56
Old 04-19-2008, 10:37 AM
ED955S's Avatar
ED955S
ED955S is offline
patsum
26
05-29-2021 06:29 PM
rob&JCW
02-21-2018 02:41 PM
rob&JCW
10-09-2015 11:12 AM
M7Speed
09-04-2015 10:47 AM
Suspension Products
09-03-2015 09:41 AM
Quick Reply: Suspension OMP or Madness Lower Brace?
