Suspension So I made myself some endlinks today...
#26
That is until they bend or break. I've seen it happen. One broke the rod about two inches from the bottom, and the other two broke at the weld joint where the rod meets the end.
This wouldn't be an issue if the end link mounted to the lower control arm like most other cars. MINI's have the added stress of having to turn with the strut and these particular rod ends just don't have enough angularity to cope.
Good discussion, everyone!!
Jim
Jim
#27
The Powergrid endlinks are the best links you can buy for the front end. These are balljoint type endlinks - like the factory design, not rod ends. High misaligned rod ends will not work either...the few I have looked at articulate 22 degrees and a typical non-high misaligned rod end articulate about 14 degrees. The Powergrid endlinks articulate 53 degrees on two axis.
NoModMini,
I'm confused...the broken bolt in the pic above does not show signs of either pure compression or tension failure. Although one side may have compressed, the other is in shear...when the link binds, the primary force responsible for failure is shear. A shear load need not be two identical forces working in opposite directions...resistance, bind, to a shear load will also cause a shear failure...??? This may appear as though we're taking the OP's subject off point, but there have been a large number of endlink failures in the mini community. Most, if not all have involved the front endlinks - because manufacturers are not paying attention to how this car works. I have similar complaints about some of the adjustable coilover kits.
Semantics aside, a garden variety rod end will not work in the front end. A ball joint type endlink as all that will work with piece of mind.
NoModMini,
#30
Wait, if you only have one side attached and you're still breaking, or about to break, end links there's something wrong with your sway bar or the end link is too long/ too short.
#33
I know what the problem is...like Meb said.. . Heims arent made to take that side force. I just need to replace them thats all...No biggie...
#34
Sorry...ever heard of Aurora Rod Ends?
http://www.aurorabearing.com/
They are not a "common, low strength rod end."
Jim
Jim
SPM = 6,340 lb rating
MM, KM, or SM = 6,660 lb rating
CM = 8,338 lb rating
AM = 16,228 lb rating
XAM = 31,390 lb rating
The main difference in these are the material and heat-treatment of the body and shank. The shank is usually where they will fail. The XAM series is the one I was attempting to point out that has the step shank. Not only does it have a larger threaded shank, but is also heat-treated alloy steel. The lower rated ones are plated carbon steel (non heat-treated).
#35
Good discussion, good discussion. To respond to the response to my response.... I work about a zillion hours a week and don't spend a whole ton of time on the forums. To describe the manufacturing process would either require me giving lessons on lathe operation, or would require me to assume that you already know how to use a lathe. And if THAT were true, then I wouldn't have to tell you how to make the parts. You'd already know.
I'm not giving online turning lessons.
If you want the abridged version...
1. measure
2. buy parts
3. buy bar stock
4. measure
5. cut stock
6. face bar stock
7. spot drill
8. drill
9. chamfer
10. tap RH
11. measure
12. flip over part
13. repeat 6-9
14. tap LH
15. clean/deburr
16. assemble
1. measure
2. buy parts
3. buy bar stock
4. measure
5. cut stock
6. face bar stock
7. spot drill
8. drill
9. chamfer
10. tap RH
11. measure
12. flip over part
13. repeat 6-9
14. tap LH
15. clean/deburr
16. assemble
#36
Most every aftermarket end link made for the Mini is a flawed design, but for the Powergrids. The rears can take anything pretty much, but the fronts can't. It has nothing to do with how strong the Hiem is, by the way Aroura is a middle of the road hiem, no where near top quality. Meb has it all right, so go back and read his post. All but Powergrid being the best. There are better.
The OP's links are nice, but it short time will start to bend at the hiem in the fronts, and then fail. In fact they might just break because of how strong they are, which could send him into a tree depending when it happens. I'd rather they be softer and bend, like the Altas do..
#37
1. measure
2. buy parts
3. buy bar stock
4. measure
5. cut stock
6. face bar stock
7. spot drill
8. drill
9. chamfer
10. tap RH
11. measure
12. flip over part
13. repeat 6-9
14. tap LH
15. clean/deburr
16. assemble
1. measure
2. buy parts
3. buy bar stock
4. measure
5. cut stock
6. face bar stock
7. spot drill
8. drill
9. chamfer
10. tap RH
11. measure
12. flip over part
13. repeat 6-9
14. tap LH
15. clean/deburr
16. assemble
I guess I just don't see where the question was even posed.
#41
High angularity rod ends are the solution
Jim and all,
The project to fabricate one's own end-links is a great one. Congratualtions.
Jim's end-link failure most likely due to bind from not using 'high angularity' rod ends, Aurora or any other make. Have poped two myself before tumbling to this simple fact. Takes very little to bind those babies up and pop the rod. Did it the first time in my own driveway, 50 feet from the car port.
John Petrich in Seattle
#42
NoModMini,
NoModMini,
#43
#44
#45
Got the endlinks installed today after experimenting with different hardware solutions.
The verdict? They are a bit noisy from the link body assembly (2 rod ends, 2 nuts, and the shaft) all rotating freely on the fixed ***** and moving until their limit (hitting the head on the affixing bolt). With the radio on, I can't hear/feel it unless there is a break in songs or a dead spot between tracks on the iPod.
I could feel the difference in stiffness just in installing them as I could flex the stock endlinks by hand when removing them from a pre-loaded bar. Installing the links with no preload proved about as easy as I expected.
These links are good for a race car for sure, but I am not too thrilled with the noise level on my street-driven Mini. I may go back to stock for now and experiment with teflon-lined joints that do not move back and forth so freely. Anyone want this set for an autocross car?
#46
#47
#49
