Suspension Swaybar end links
Old 04-11-2008, 03:40 PM
Crashton's Avatar
Crashton
Crashton is offline
I'm no expert, but I believe you will end up with the ends of your swaybars pointing upward. That will put the bars in a bind. If I understand correctly you'll need some adjustable links so you can bring the swaybar ends parallel.
  #27
Old 04-12-2008, 08:26 AM
motorer03's Avatar
motorer03
motorer03 is offline
so i would want to have the sway bar ends pointing straight backwards? and should i do this by setting my ride height with the links disconnected and then measure with the car on the ground?
  #28
Old 04-12-2008, 07:32 PM
S-Driver's Avatar
S-Driver
S-Driver is offline
My Alta endlinks (rear) are as short as they could go and the sway bar still cants upwards a bit...
  #29
Old 04-17-2008, 07:57 PM
minimarks's Avatar
minimarks
minimarks is offline
I have the TSW springs so the car is lowered about one inch and the swaybars are slanted upwards. Will the ride be effected if I take out the preload and will I get a little more traction on the front wheels?
xpunisherx
11-27-2015 03:32 PM
wesmc
R55 :: Clubman Talk (2008+)
09-28-2015 12:07 PM
Ntety
09-02-2015 08:39 PM
09-02-2015 11:15 AM
Suspension Products
09-02-2015 10:32 AM
Quick Reply: Suspension Swaybar end links
