SuspensionSprings, struts, coilovers, sway-bars, camber plates, and all other modifications to suspension components for Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs.
Quick question, getting the 14-12mm stud conversion kit allows you to mount a wider selection of wheels, but will it have any effect on the R56 stock wheels that normally fit w/ 14mm? (eg. bridgespokes or crownspokes) TIA
They work fine with all of the OEM MINI wheels, except for the wheels that have a decorative pop-off center cap covering the bolt holes.
I've been using conversion studs with my Webspokes for about 50k miles now.
I have one of the early conversion stud sets from TSW, so things may have changed now, but yes, I have a significant amount of surface rust on the studs. Every now and then I just clean it off and grease the exposed threads to provide some measure of protection.
The new coating we spec'd has solved this issue...
