Suspension Just installed H&R Lowering Springs
Took less than 2 hours to perform the work w/ a compressor. 200 mile drive reivew...Looks great now just rides like crap. Hitting bump stops now over the same roads traveled...yeah corners better but pray there isn't a bump/dip in the turn....but it does look damn good
But yes...as said above you have to cut the bumpstop about in half from what I've read. I'd check a DIY for springs...Maybe Alta has one?
Here is a link to the write up Adam from Alta did about his install
https://www.northamericanmotoring.co...t=%22Howard%22
I had the problem of hitting the bump stops and a overzealous rebound feeling with the Mach V springs I put on. I ended up taking them off. I bounced a few msgs back and forth with Dan at Mach V describing what I felt and that I thought it was out of balance and he never once suggested touching the bump stops.
Is that really a good idea? Can any experts endorse this?
OEM shocks can not handle the increased spring rate. So they speed of the travel is uncontrolled. Cutting the bump stops will stop the sound from happening all the time. But will cause the shocks to move out of it's design range (hence that is why they are that length) and will still not be able to control the wheel properly.
Solution....
Koni make great dampers for the r56 that can take up to 500lbs.in springs. And probably others with time.
Solution....
Solution....
Solution....
I've been looking for the Koni sport dampers to become available for the R56 these but they are not listed on the Koni site. You have to go back to R50/R53 years for anything to come up. From what I understand the rear shocks are different. fastmini.net sells them with adapters. I wonder if this is ideal or if the Koni's that come out for the R56 will be tuned any differently along with fitting properly. Consequently I'm waiting for the official release before I spend any more money on suspension experiments. I had Koni's on a previous car and the handling improvement was nothing short of stunning.
They make replacements for the R56 now. You have to sacrifice your stock front damper housing to press in the insterst and the rear as only adjustable if you take off the damper to get at the settings. NO the best situation but for 800 $ the best performance upgrade you can make.
Also, I might as well address those that for some reason thing their dampers are going to "blow out". The dampers were designed to rebound against the factory bumpstop. Cutting the bumpstop will dramatically change that rebound interaction, creating a "dead" ride that actually doesn't allow the car to properly articulate its suspension over large undulations. For what it's worth, the spring rate of the bumpstops is additive to the coil spring, and the damper IS designed for that net spring rate. As long as the lowering spring has a reasonably similar spring rate, the lowered setup isn't going to hurt anything except perhaps your fillings.
Cheers,
Ryan
The MINI is a bumpstop-active system. Even at stock ride height the smallest bump will begin compressing the highly compressible and soft bumpers [aka foam bumpstops], which have about a 1.5" compression ability. When you use lowering springs, you move the suspension ride height into the compressed region of the bumpstop, so this means large bumps will be much more progressive [aka jarring].
Cheers,
Ryan
Cheers,
Ryan
That said, one of my personal criteria is minimal to no lowering so the Koni shocks sound good to me. The car is low enough for the road quality in my area. Do any of the coilover options out there allow close to stock height? Everything I've looked into lowers a minimum of 3/4" and I am told not to count on that number being entirely correct.
Still, I will try to arrange a test drive in M7's R56 to experience their coilovers when I'm in Sou Cal at the beginning of July.
on
Cheers,
Ryan
Cheers,
Ryan
Go coilovers guys!
