Suspension Help Need MINI Suspension 101
on
Please, I searched for a basic instruction on what is involved in suspension
(basic, like there are struts, some kind of links? Some other stuff? )
Is there a beginner's thread I can't find?
With 66K miles on my 2002 MCS, I'm having a really rough ride on bumps,
sometimes I bottom out. I can tell my suspension is shot.
I have an Alta rear swaybar, running on 17" Toyo Proxes.
I do plan to downgrade to a more comfortable tire when I replace them,
Although maybe it is the uncomfortable suspension that is the problem...
I have NO idea what all is involved in suspension,
what pieces there are, what I should be looking to replace/upgrade.
I have done a search, but it is all beyond my understanding,
which is obviously nil..and I'm a daily driver, aggressive
when I get the chance
I'm confused about what's involved in suspension more than struts,
and what else could be shot.
My local MINI dealer has proven to be unreliable and uninformed, so
as usual, I have to figure it out for myself, and except for Randy's pulley
I have installed everything else on my car myself.
"Nuff said, please point me in the right direction. thanks
For the most part struts and springs and upper strut bearings are the basic parts.
Struts are probably worn out or getting close at 66k. That is the black part in the picture below borrowed from k-huevo.
The upper strut bearings might also be worn out. You can't see those in the pic below but they go at the top of the spring and attach the strut + spring assembly to the strut towers on the chassis.
Springs usually last a long time so I doubt those are the cause of your suspension woes. I have a set of JCW springs I'm selling if you are looking for a good spring.
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
on
Think about replacing your coilovers with a set of Megan's. You will be able to adjust height and ride comfort. http://www.autoxcooper.com/megan.html about 1/2 down for more info or PM me.
So, you're out of warranty as well. You'll probably be not surprised on how much the dealer wants for the stock bits. So go aftermarket. Find a local mini group and take rides with different suspension set ups.
My ride with oem struts was getting worse after 50k. I went for Koni FSD's. Kept the stock springs. Went with fixed camber plates for replacing the upper strut bearings. no adjust, no fuss, no muss. Still at stock height, but additional front camber. Better grip through fast sweepers. The only other strut recommendation is Bilstein SP. if you want to spend more, you will have more options.
More adjustability means more suspension sorting.
on
To understand the systems...
there are good graphics of generic stuff at "the car bibles" web site. We have MacPherson strut up front, and a trailing arm rear (yeah, I know, BMW likes to call it a "multi-link" suspension, but it's still a trailing arm geometry.)
At your mileage, if it's gotten worse over time, I'd be betting on the rubber control arm bushing and struts, with my money on the control arm bushings.
If you were happy how it was and don't want to spend tons of money, you can get new bushings for the control arms, and buy stock struts used from someone who's upgraded the suspension. If you want to improve your ride, there are a million ways to skin that cat, some that you will like more than others. I'm sure there are a thousand of opionions that will be offered if you want them...
Other wear points in the front suspension are:
Ball joints (two on each side)
End links (they get loose and rattle more than cause bottoming)
Upper strut guide (the rubber can get tired or tear)
Upper spring perch (these have cracked on some cars)
Sway bar bushings (these contribute to noise if they go, more than ride issues)
I think that covers it....
Matt
Matt
Ouch! Thanks for the clarification. More parts to check.
on
You guys come through, as always
If I get my ideal suspension plan, but I probably won't be able to do it
all at once,
I could start with struts and control arm bushings?
(and replace anything else with obvious wear...)
and then upgrade in sections
if say the ball joints are worn but I don 't do them initially,
will I just wear the newer parts?
If so, maybe I"ll have to get this diagnosed...then do the
upgrades myself...
all at once,
upgrades myself...
To do the control arm bushings...
you need to use a hydrolic press, or a BMW tool that allows for exhange while parts are mounted in the car. If you don't have the magic tool, then you have to drop the subframe. It's really easy to do the ball joints at the same time, but you don't have to.
Get the diagnosis (most you can actually do yourself), find out where your actual problem is, then see what's easy to replace at the same time...
Matt
Matt
Although it is a lot of work, I replaced rear lower control arms, rear trailing arm bushings, inner and outer ball joints, inner and outer tie rods, front swaybar budshings and replaced the Power flex LCA bushing with a new Powerflex unit. Along with a new JCW suspension kit, four new swaybar endlinks and new rear Webb swaybar bar bushings, the car feels fantastic - as it should!
As an aside, would some of my friends here please use jack stands and not wood and concrete? I would like to feel we're all in this for fun and that we'll all be around for a long, long while. By over-rated jackstands and use these on level ground. Jack stands are safer!
07-16-2020 12:54 PM
minicoclub
11-11-2015 07:25 AM
PelicanParts.com
08-04-2015 02:45 PM
