Suspension Lookin to lower my MCS...
Old 08-11-2008, 05:37 PM
Ryephile's Avatar
Ryephile
Ryephile is offline
Yes it does exist...and it's SUPER cool driving one of those 7-ers as they have NO body roll no matter how hard you corner. Ok, actually they program in 0.5 degree up to 0.5g lateral, and IIRC it ramps up to 2 degrees at full lateral grip.
BMW uses an electro-hydraulic [sic] coupler that controls two anti-roll bar halves, which is connected to a controller/actuator. It's super cool.
  #27
Old 09-28-2008, 03:44 PM
DVSAZN's Avatar
DVSAZN
DVSAZN is offline
Okay, I've decided to go with H&R springs to lower my R56....
Now my question is will I be able to bring camber back to spec off of stock??
If not then which rear control arm does everyone recommend??
I was looking at TSW or Megan control arms...
Help?
  #28
Old 09-28-2008, 05:33 PM
Ryephile's Avatar
Ryephile
Ryephile is offline
You don't need anything additional. Use the factory rear lower control arm outer eccentric bolts to correct the camber. The easy way is to adjust them so the knuckle bottoms are pushed furthest towards the vehicle center [most positive camber]. At ride height with your H&R spings, it'll yield about -1.0 degree camber in back.
There's minimal adjustment in front. The strut towers are mildly slotted and can add about -0.5 degrees. Also, be sure to check your front toe, as lowering the front will change the toe slightly. You want to end up with zero toe or 1/16" toe-in.
Cheers,
Ryan
  #29
Old 10-13-2008, 05:43 PM
DVSAZN's Avatar
DVSAZN
DVSAZN is offline
Dropped and got new shoes!
Haven't cleaned her yet....
  #30
Old 10-13-2008, 07:00 PM
JAS76's Avatar
JAS76
JAS76 is offline
looks great! What wheels are those?
  #31
Old 10-13-2008, 07:35 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Rally@StanceDesign is offline
DV, Those look really good
  #32
Old 10-14-2008, 05:30 AM
DVSAZN's Avatar
DVSAZN
DVSAZN is offline
Thanks, they are flat black Tenzo M's Version 1...
17x7 +42, wrapped with Yokohama Avid H4's, 205/40/17...
Oh, and the funny thing is I took her to get aligned on Monday... Camber was all within spec! Caster & tow need a little adjusting in the front but that was about it!
H&R's are smoother on local roads then stock but a little rougher on the highway vs. stock...
  #33
Old 10-15-2008, 08:23 AM
scruffylooking's Avatar
scruffylooking
scruffylooking is offline
Those are pretty nice looking wheels! I wish they weren't 8 hole universal 4 hole but nevertheless... sweet ride!
smdmini
10-07-2019 06:05 AM
massmini03
09-18-2015 05:40 PM
hydouken
09-15-2015 05:49 AM
Accessory Products
09-09-2015 10:29 AM
09-02-2015 11:15 AM
Quick Reply: Suspension Lookin to lower my MCS...
