Suspension Alta 19mm rear antisway bar installed.
Installed Alta 19mm rear antisway bar past Saturday. With my front M7 strut tower brace, I had noticed significant decrease in torque steer but noticed exaggerated swaying of my rear during tight & fast turns. I bit the bullet & following advises of this forum, I changed the bar & put it on its middle setting.
After driving for last 2 days, I am very pleased with "crisp" turn in & easily controllable understeer with throttle during hard cornering. My rear end just became so much more predictable that I feel I have so much more "time" to further fine tune with throttle to lessen understeer
I might have to try the stiffest setting now .....
Now, how is that H&R springs......
Same here. I have each part with the bolts in separate boxes, labeled of course! I'm keeping the car for years, but I woe the day when I have to put it all back together! Hopefully it will be a college chap who won't mind the aftermarket...
Minitauro, Fit & finish are first rate. I have stock intake & the bar has about 3/4 inch clearance from air box. Driving in forward gears, I have no rubbing issues. Driving in reverse, I do hear rubbing noise at times when I am more aggressive. I opened the hood & verified where they rub & there are no significant damages. I figure, it's divine message for me to reverse out slooowly..... (My last two "bumps" were while driving in reverse).
I felt definite attenuation of torque steer with my STB. But, with your coilovers & lowering, you may already have decreased TS as is.
I'm gonna test the car this weekend with STB disconnected & see the difference.
I read that some with STB put felt where it rubs with filter box: I will eventually do something as well....
ebowling
90
08-04-2019 09:15 AM
